Rear brake
do any of you guys use rear brake at all under heavy braking? many say they dont touch their rear brake
Yes. I use mine all the time. Personally, I think people who say "don't use the rear brake" are scared of it and don't have the skill to properly modulate it so the rear tire doesn't lock up.
Using the rear while trail braking in a corner helps tighten your line without upsetting the suspension. You can use the front brake as well, but very lightly. As you use more traction for turning the motorcycle, you have less available for braking or acceleration. |
I use it softly when coming to a full stop if im coming in hot...
Definitely use the rear brake, almost all the time. Especially under heavy braking.
Mostly during downshift for a quick redlight, so I can blip throttle. If you lock up the rear, hold it til you stop. If you lock up the front, you better let go and retry. |
Breaking hard, sure.
Originally Posted by vfrman
(Post 1163240)
Using the rear while trail braking in a corner helps tighten your line without upsetting the suspension. You can use the front brake as well, but very lightly. As you use more traction for turning the motorcycle, you have less available for braking or acceleration. Not true my buddy uses it an i out brake him every time, my rear tire usually come off the ground braking into turns so it would be impossible to modulate the rear brake. And i find using the front brake to trail brake is much better as it keeps the forks compressed an let you turn in much faster. I do use the rear brake on one track when im cresting a hill to stop myself from doing a wheelie so i can keep it pinned. |
To be honest the front brake can get you into much more trouble. And I believe any experienced rider will tell you this. Rear wheel lockups are easy to control and get out of. Highsides or other occurrences from too much front brake... can be deadly.
Always keep in mind though the front brake does have more force. Honestly you should get into the habit of using both simultaneously. |
Originally Posted by BorderLineAlaska
(Post 1215207)
Always keep in mind though the front brake does have more force. Honestly you should get into the habit of using both simultaneously. How does a highside occur because of using too much front brake? Highsides usually occur because a rider locked up the rear, slid the rear tire and released the rear brake, or because he spun the rear tire and suddenly regained traction after chopping the throttle. Riders are fearful of using the front brake as hard as it is designed to be used because they receive misinformation about the front brake and because they don't take the time to practice emergency braking or hard braking with the front. Whether you choose to use front brake only or a combination of front and rear, the front brake more likely has a lot more braking capability than most riders are utilizing. How might you go about improving your overall braking proficiency? Misti |
I'm definitely all front brake when under heavy braking. My reasons being that for my skill level I don't think I have enough control not to lock up the rear, plus, I want to keep things simple.
I do use the rear brake but only in slow speed, controled braking. Braking is one of my favorite things to practice actually. I use the old tennis-balls-cut-in-half trick as markers on the ground for start-to-brake and stop positions and work on getting them closer together for a given speed. It's most fun with a buddy so you can try and out brake each other. |
Originally Posted by Misti
(Post 1216320)
Front brake has a lot more braking force and is in fact capable of doing 100% of the braking on most sportbikes. When racing, AMA supersport and FX I used front brake only except if I ended up off track or in the dirt.
So on the track subject, how do ppl compensate for that? How does a highside occur because of using too much front brake? Highsides usually occur because a rider locked up the rear, slid the rear tire and released the rear brake, or because he spun the rear tire and suddenly regained traction after chopping the throttle. Riders are fearful of using the front brake as hard as it is designed to be used because they receive misinformation about the front brake and because they don't take the time to practice emergency braking or hard braking with the front. Whether you choose to use front brake only or a combination of front and rear, the front brake more likely has a lot more braking capability than most riders are utilizing. How might you go about improving your overall braking proficiency? Misti Otherwise a person can only REALLY improve to their mental limit, how far they're willing to push things before they chicken out. Leaving a gap between mental and actual limit they may need to avoid an accident / trail brake deeper into the corner / etc... |
| All times are GMT -5. The time now is 05:49 AM. |
