Wheelie RPM Question
Im new to wheelies and I wanted to ask if this is a correct conclusion:
it doesnt matter how fast your going and how high your rpm is when you grab the clutch, what matters is how much you bring the rpm up after you grab the clutch.
Example: The Rpm was 7k and I tried wheelie at 11k-12k but it didnt pop up
however when i was at 5k and i tried wheelie at 11k-10k and it pops up
is this correct?
Thanks!
is this correct?
Thanks!
You have an f3 correct? And do you have 15/43 sprockets?
Because with these stock sprockets you should have ease in 1st, and even 2nd gear, as you get better.
If you're at 7k in w/e gear and you clutch-rev. to 11k, then that means you're moving faster than when at 5k.
Leaning back on the seat more (if doing sit-downs) will help you when you're trying to pop it up, when moving faster!
