Steering Dampeners?
RE: Steering Dampeners?
A tank slapper can happen from a stoppie or a wheelie. When your up in a wheelie,and you put the front end down a little crooked,the handle bars will start slapping back and fourth where you cant control it,and you will most likely be kissing the pavement seconds after. A steering damp will help eliminate head shake by making the front much more stiff. You can adjust them to what ever firmness you like. Go with a scotts damp,costs around 4 or 5 hundred. But will save your ****. Plenty of tank slappers on u tube if you want to see one. Or if you want to expierence one for your self,go do a wheelie,and put your front end down a little crooked. You'll be sliding on the pavement in no time
do you think i can modify a 1000rr steering damp?
http://cgi.ebay.com/ebaymotors/04-Ho...spagenameZWD1V
thanks
JonBrown
thanks
JonBrown
ORIGINAL: JonBrown
thanks
JonBrown
thanks
JonBrown
ORIGINAL: DThompson
Actually its spelled Dampner, Dampener, and Damper. Alot of companies spell it differently but who really cares.
ORIGINAL: bergs
You aren't making it wet are ya?
It's spelled "damper"...same as suspension "dampers"
I can't help it...sorry.
Grammar lesson, over.
