How Do I Clutch Wheelie - Moved
its not quite that simple....
on the f4 a good start point on a stock geared bike:
second gear around 50mph this will have you around 6grand, pull clutch apply throttle and release clutch in a single smooth motion, start with a small throttle clutch up, you can always work your way up, overdoing it the first time will have bad results.
Stand up, put your left foot on the rear passenger peg before you clutch up, this will be verry helpfull for learning, keep your right foot over the back break, you should not need to shift gears in a wheelie if you get the propper balance point
well
I've done different types of wheelies. Power wheelies are easiest and seem to me, to be the easiest to control, to me anyways.
Center yourself standing on the pegs (front to back and side to side) and "bounce the suspension. do this a couple of times to understand how your bike is going to respond. after youve got your timing down start rebounding the suspension with little blips of the throttle. like said earlier in this post, baby steps. timing the rebound of the suspension and use of the right gear and speed is going to crucial.
also, think about this. if you're standing straight up (12 o'clock) and the bike's in front of you, then your not looping it, LOL i did standups and never really wanted to go back to sitting on wheelies.
if your using your full suspension front and rear, you can bring the wheelie up at lower revs. it's all technique. the more he practices the quicker he'll be in a balance point and have more to work with. i'm just not partial to clutch wheelies cause its hard on the clutch and chain (initial snap up puts more stress on all parts) and with practice, and using the whole suspension, it becomes a lot smoother and easier to control. just my 2 cents.
