Burnout question
RE: Burnout question
[align=left]First start off coming in at about 5 mph. (NOW DO ALL OF THIS AT THE SAME TIME) pull in clutch get out of the seat and lean forward up to the windscreen.get your revs up pretty good. with two fingers(index and next to index) grab barely enough front brake to SLOW the wheel. then quickly dump the clutch to get the back wheel "lit" up. DON"T slip the clutch cause the you'll load up the front and slide the front wheel or you'll fry it. Just practice on some good asphalt or your favorite Sonic Drive In....If you're in JAX, FL hit me up and we can do some together
[/align]
[/align]
