Bike setup for eveyone
[align=center] Bike Set-Up[/align] [align=left] 12 BAR - Your 12 bar needs to be as wide as the bike, if not a little wider. (12-14 inches wide) thickness needs to be 2-4 inches. The wider the bar, the more stable it will be when it is parked or when your sliding on the tail. Click here for more pics of 12 bars.
[/align] [align=left] CRASH CAGE - freestyle integuinity A crash cage will help save your bike from damage when you lay it down. It especially helps eleminate broken cases. A crash cage is a must have. Click here for more crash cage pics.[/align] [align=left] [/align] [align=left][/align] [align=left] STEEL LINES - Steel lines help prevent brake fade. Brake fade is caused by normal lines expanding due to heat and pressure. When brake fade occurs the brakes simply stop working and will start working again when the lines cool down. AND USE Motul RBF600 BRAKE FLUID.
[/align] [align=left][/align] [align=left] SUSPENSION -You should make your forks a little stiff. turned them a few clicks harder so my suspension will not dive to much when I do stoppies. Also makes it a little easier on you when you put your front wheel down while doing a wheelie![/align] [align=left][/align] [align=left] smashing in the gas tank - A smashed gas tank is used as a dance floor, it makes tank wheelies, switchbacks, christ's and spindarellas much much easier, and safer! best way is to have a few people hold your bike up, then stand up on tank in christ position, then jump up and down lightly tel tank is caved in. also a good way is to do high chair stoppies. when you let the bike down from a stoppie your body weight will automaticly put force on the tank and cause it to dent in. this is a good way too, cause then your tank is more likely to match your butt! Click here for video & more pics.
[/align] [align=left][/align] [align=left] [color="#000000"][font="copperplate gothic light"]GEARING - Click here for http://www.thrustcompany.com/[/f
IndyHooligan
04-14-2012 12:20 PM
