Bigger sprocket
Yep, you can do a 46 easily.
Example:
F4 stock sizes: 16/45 & 108 link chain (manual says 110 but 108 still gives full range for adjusters)
F4i stock sizes: 16/46 & 108 links
So you're good to go up to 46 w/ your chain unless its less than 108 links.
Example:
No, you cannot use an F4i sprocket. The sprocket carriers are different between the two bikes. You need an F4 sprocket to match the F4 sprocket carrier's bolt pattern.
But you *can* use the 46 teeth you were asking about.
ok thanks gotcbr,one more thing since the stock chain is a 525 and if i was to go down to a 520 chain, can the 46 teeth sprocket for a 525 chain work on the 520 chain or at the teeth to big,, and i think im messing up the numbers
^ I thought I was clear on that above. ;-)
