After been wheelie-ing, somewhere squeaks
Hi all,
I have recently become more and more comfortable lifting the front wheel. After doing wheelies the mast few month, I now hear a squeaking noise from the slightest movement or weight shift on my bike. I can not determine where exactly the squeaking is coming from, but it is towards the center of the bike. Has anyone else experienced a similiar problem? Thanks all, Jason |
RE: After been wheelie-ing, somewhere squeaks
I learned that if you keep doing wheelies your bike is going to squeak, bolts will be coming loose and your **** will start breaking. Thats why bikes that get stunted look the way they do. I broke my wind shield doing a normal wheelie because of doing special k's, just set her down and snap I heard it break, I was like damn. so if your worried about your bike getting squeaky then you should stop doing wheelies while you can. Its probably your seat or tank or plastics moving a bit check it out, if you don't find it go buy some jig-a-loo and spray your bike down that should fix it... later
ya it could really be anything, but if its squeaking while you are on the bike, then check the subframe bolts. i know that after a while of doing nothing but scrapes, that my bolts loosen up.
ORIGINAL: inlikefletch Hi all, I have recently become more and more comfortable lifting the front wheel. After doing wheelies the mast few month, I now hear a squeaking noise from the slightest movement or weight shift on my bike. I can not determine where exactly the squeaking is coming from, but it is towards the center of the bike. Has anyone else experienced a similiar problem? Thanks all, Jason |
