What do you do? #1
Im gonna try something different. I'm going to give a scenario and ask "what do yo do?'. See the problem is by nature if we don't know what to do in a situation, we generally tend to respond instinctually. And a lot of times, our instincts are wrong. Potentially dead wrong.
So this one happened today. I was riding in unfamiliar territory and took a freeway exit. The warning sign suggested a speed of 25 MPH. I was going about 45 - 50 MPH. My line selection wasn't the best. But it would have been adequate... if the turn was the length I expected. It was not. So I'm running hot and, with no exit point in sight, I'm gonna run wide. Wide as in "not another curb!!!". And I was at maximum lean (at least mentally). So how do you correct this situation? Obviously I didn't hit the curb. I'll let y'all know what I did after a few responses. And no, I didn't lean harder cause mentally I was maxed out. |
Add some counter steer?
Brake?
Either trail brake or believe it or not, get harder on the gas loading the rear tire, changing the center of gravity on the bike and forcing the bike to sharpen its' turning radius.
Of course, and I'm not trying to be a dick, but you again seem to have gotten yourself into another classic rookie situation. I'd really really suggest you take a serious bike class, spend some time on a track or park that thing before you run out of lives my friend. I mean that seriously dude. Sorry. |
Idk....throttle thru and press the inside bar....
Do use the suggested speed signs, from my experience driving a truck I know those signs save life’s and are not something to be ignored, but if I did get myself into that situation, I'd probably start trail braking.
Originally Posted by zaqwert6
(Post 1163792)
Of course, and I'm not trying to be a dick, but you again seem to have gotten yourself into another classic rookie situation. I'd really really suggest you take a serious bike class, spend some time on a track or park that thing before you run out of lives my friend. I mean that seriously dude. Sorry. Trail braking is something I wouldn't suggest initially. Its a bit advanced. And for me, it's something I'm still practicing on the BMW. I went a bit simpler in solving the problem: I tapped the rear brake and stayed on the throttle |
Ya I know....
You went hot, nearly twice the suggested speed, into an unknown and apparently blind turn, on a new bike your clearly not comfortable with yet, that you've already put down in a turn once and nearly totalled, not to mention been struggling with suspension settings AND otherwise, and on the street no less..... Theres enough beginner mistakes in there to kill someone 2,3 or 4 times. I've lost too many poeple just like this. I'm fine with you thinking I'm a dick for saying it but I don't want to read about you in the fallen riders forum and live the rest of my life thinking if I said something you'd still be here. So there I said my peace. Take it for what you will or not, I'll butt out from here on in promise. Good luck in all you do ,I mean that. |
(Post 1163920)
Ya I know....
(Post 1163792)
...get harder on the gas loading the rear tire, changing the center of gravity on the bike and forcing the bike to sharpen its' turning radius.
Also more gas means more velocity, which means more traction/lean angle to keep the same radius. Kuro did the right thing (well, one of them). Using the rear brake while cornering helps scrub speed and tighten the line (reduce radius) with minimal upsetting of the chassis. |
