SSSA conversion
Hi folks I'm in the process of doing a SSSA converson, I will start a thread soon to show it but at the moment I have come across a small problem, I have mounted the shock on top of the swing arm and it had made the rear end way to high, I'm thinking a shorter shock may be the answer, so my question is, does anyone know of a shorter shock from any bike which will fit std top and bottom shock fittings?
Cheers Paul |
found this on CF from oldskoolsuzuki.com
http://www.customfighters.com/forums...9fcdc17307.jpg http://www.customfighters.com/forums...9fcdc18a76.jpg http://www.customfighters.com/forums...9fcdc1a1e5.jpg http://www.customfighters.com/forums...9fcdc1b954.jpg 954 and 929 look like the shortest ones. but it'd help to know what bike you have |
I'm doing this swap once i'm home in a month. I don't know how much fab work you're wanting to do but i'm planning on using the vfr shock and shock linkage and i'm just going to fab up a new upper shock mount. Let me know what you end up going with. Good luck!
