Re. Hornet cluster for CBR
Trying to keep using the old school analog gauges and thought of using this:
Amazon.com: Motorcycle Fittings Dashboard Instrument Cluster Gauge Clock Speedometer Fit For CB250 Hornet 1995 1996 1997 1998: Automotive
Any thoughts or should I just upgrade to using a F4 or newer CRB cluster? Thanks. |
It all depends on how the Hornet gets it's signal. I see plugs on the cluster, but does the Hornet use any cables (speed and/or RPM)? For $150, there is a plethora of aftermarket options that will accomplish what you're trying to do. I would get away from OEM clusters for your bike because of their physical size. For the money, you can get a much smaller unit(s) that will better serve your bike's aesthetics.
