Hiding Wires
Old Sep 15, 2013 | 07:54 PM
GPiper's Avatar
Default Hiding Wires
Anybody able to show some good ways to hide the mass of wires and help with what are the better ways to dress that area up. Lot's of tight rides here...like to take some of the ideas.
Old Sep 15, 2013 | 10:26 PM
Conrice's Avatar
Cut. Splice. Solder. Shrink wrap.
It's a PITA - but you get to run the wiring any way you want then. It's a fun way to spend a weekend day. There's no specific way to do it, you just run everything inside the frame instead of outside. Shorten sub harnesses for the gauge, headlights, etc.
Old Sep 15, 2013 | 10:34 PM
GPiper's Avatar
I want to keep the harness intact as much as possible, the wife will get it when I find something bigger (750 or bigger) and she might want the fairings back on it. Wants to paint it "Pretty".
Old Sep 16, 2013 | 06:17 AM
Conrice's Avatar
Well, you should be able to run the wiring still inside the frame. Unplug stuff, and get the harness inside, see what you can do with it.
Old Sep 16, 2013 | 09:39 PM
GPiper's Avatar
I appreciate the input, Conrice. I checked out you project, that VFR swingarm is sick. Got in some practice moving wires around today cleaning up under the seat. I don't like how wide the seat is, especially without the fairings, but my 43 yr old a$$ needs some real padding. I had an old atv seat laying around and started cutting on it. If I turn it around backwards it looks like a two-seater with kind of a bopper tail. I think I might try it for a while, certainly much more narrow.
Attached Thumbnails Hiding Wires-seat-width.jpg   Hiding Wires-long-bobber.jpg
Old Sep 17, 2013 | 08:25 AM
Conrice's Avatar
Ah man! Post some more pics! That is looking good, but what seat is that? The F2/F3 is kind of hard because of the rear frame. Are you planning on running those tail fairings again, or no? If not, you could try moving some of the relays and what not up underneath the tank. Of course, that would probably require soldering. I seem to remember someone making a bigger box underneath the seat and stuffing everything in there.
The__Rider
Mar 26, 2011 12:13 AM
Kuroshio
Jul 10, 2010 11:20 AM
underground-mpyre
Jul 22, 2009 07:40 PM
jonny599
Apr 26, 2008 02:09 PM
TimBucTwo
Feb 22, 2007 12:53 AM
