Conrice's 954 FIGHTER build thread
#51
here she is at this moment
i'm going to be building a subframe for it from scratch. i've got these 3 mounts to build it from on both sides.
if i make it out of steel, it'll be heavier, but i can have it come right up close underneath the seat and won't need much of a support arm for it - which is what i want to do i think. however, i couldn't believe how friggin' light the stock subframe was for it, so i may make it out of aluminum, suck it up and deal with having a support arm that sticks out like a sore thumb.
and here's the motor i'm going to eventually be putting into it.
it's not much to look at right now, but in a few months, its going to be the ride of my dreams
#53
uhhh not really. i've just kinda decided some stuff. i've been really busy at work, i went out of town, and fought a cold for the past few weeks, so i haven't had anytime to do anything except think about it.
so instead of building my own subframe from scratch (like i originally planned), i'll be heavily modifying the orig. 954 subframe instead. i'm making it a solo-seater (the wife has her own bike anyways) - so the good thing is - is that it'll be aluminum - hella light (compared to steel). as well, i've decided on the tail i want to do - i'm going to be doing a current era 1000rr tail. and i found a real bitchin' one on ebay that is all carbon fiber to keep with the lightweight theme.
like this
i wanted to do a ktm rc8 tail - or a s1000rr tail - but they're too expensive... and right now, i just don't have enough skill to pull off my own tail. but i'll be doing a similar set up to the taylor made undertail kit for it - except without the hump. i want it to kind of look something like this
i'll start workin on it soon, i've got the subframe ready to go, need to buy the tail, and then i'll get crackin on it.
til then...
like this
til then...
#55
I'm sure this was light hearted but ironically, I just happen to be sitting here reading this thread with 4 stitches in my foot.
Yesterday while 'tinkering' in the garage a drill with 1/4" drill bit tipped off the bench, hitting the trigger on the way,
and literally drilled a hole thru my foot and into my sandal as it hit. Never even saw it fall while I was focussed elsewhere.
So of course I feel the need to find fault with that statement.
Nice build BTW.
Nice build BTW.
#56
#57
yup, and you know what else sucks.... walking around in the garage barefoot and getting slivers of aluminum stock stuck in your heels!
yes, it was light hearted.... i try to wear at least shoes when i do my own stuff in my garage. that day i clearly wasn't. i know it's probably not the safest.... but in SW florida, its the only thing i can do to beat the heat.
sorry you had something dropped on your toe... that does suck. hopefully it recovers fully and quickly for you.
Tail got here... i did go with a tekarbon one. i'll get a pic of it when i get more pics of the repsol tmr for the ROTM contest.
btw, it looks amazing.
throttle bodies from an 09 cbr100rr w/ airbox are also on the way. (bigger is better right? - 42mm TB 954 vs 46mm TB for 08-11 1000rr)
and just to be on the safe side, i'm also using a 1000rr throttle tube and kill switch.
but from here, i'm kind of stuck. i'd "like" to use a 1000rr wiring harness so that i could really have control of the dual injector set up - but i'm seeing some issues come up. cam position sensor and crank position sensor. i feel confident that i could figure out a way to make the cam sensor work - but the crank sensor looks completely different.
we'll see. 'til next time (and i promise i'll have pics)
#59
#60
and hey, since you're in orlando, have you ever heard of precision cycle inc.? have you ever dealt with them. they're the closest to me that will do motorcycle sleeving, but i've never heard of them. i'm wondering if they're good.
look at that tail.... she's purtty.
i cannot believe the difference in size between the 954 tail and that. the subframe is going to need a LOT of modifying. but it'll be fun. i'm goin out of town for 5 days, so i probably won't really get started until after the first of the year.
