03 F4I progressing build
so i believe my last thread is dead.. so here it goes, 03 f4i, 954 front end. just finally got it running on all 4 cyl due to last owner had wiring issues and maint was way off. right now ive just finished the cluster mount but looks amazing. i used a 60k aluminum and radialed the bends for vibration. have templates for the headlight mount as of today will have pics up of those on the bike tomorrow. but here ya go. and currently working on a new splash for the old subframe i had on there. and also making new heel guards and they will be shaped as the honda wing.
u prob should've updated ur other thread. its not that its dead, it jus gets pushed down if you don't update it often. just a thought.
r u gonna keep the frame green? what about the wheels? what kind of headlight r u gonna go with?
if i were u, i would keep the ram air tubes jus cuz u might lose some mid & high range power. i experienced that with my 929 and i kept mine on.
it will be red frame and sub with black arm as of now with red rims.
the bike has 42t up in the rear and it pulls power wheelies at about 8k in second and floats in third. kinda scary coming around a corner with mid way through and floating the front tire with the bald rear but fun. but then again this is my first fighter aswell as an f4i so i do not know the diff but if its that huge i will get the ducts.
thanks for the input. im looking for f4i rearset clips for the shifter and brake side i believe there like an E clip or the ones you have a retainer for but id like to get some if anyone has a spare set..
haha yeah i actually designed a non lethal rocket system for this that i could fab on to my bike and launch by using a button but there would be alot of people that wouldnt agree with it and id get introuble not to mention FAA laws. i thought about it though for all those people. lol
update on the bike. i let it sit for a week which isnt the problem but i started it and its smoking bad spitting oil out of the midpipe flange. tore it down and my valve seals are junk and also rings are bad... throwing the engine aside for a ultralight prerunner and looking for a used one now with around 10k to 15k on it so my title will not get altered... i will update you guys on whats going on with it as i will progress the build until i find a motor in my area...
the temp are for the 954 trees but im sure you could twist a fab alittle to make work but making a template right now for ya with all bends radials and what size aluminum i have used, with notes. i will get that to you very shortly. i will post it here for anyone else who wants to save and tweak there own way....
