-   Stickies (https://cbrforum.com/forum/stickies-91/)
-   -   How To: Repair Your F3 Fuel Pump (https://cbrforum.com/forum/stickies-91/how-repair-your-f3-fuel-pump-102151/)
Bazza Aug 28, 2012 05:43 PM
Replaced Fuel pump switch. Still have a problem.
Just replaced my fuel pump switch and bike starts ok but when I ride it it splutters and cuts out.
Ok just done a check to see if fuel pump works...it does without the hoses from the tank and to the carbs connected, as soon as I connect the hoses it stops working.
Found a temporary solution at bikersinegpyt have turned the bike into gravity feed by removing the fuel filter and its hoses and connecting the hose going to the carbs straight to the tank. Have run the bike now with the fuel tap turned to reserve as its supposed to give more pressure from the tank. Works ok but off to get a new fuel filter and try again.
Anyone here running an F3 on gravity feed.
Bazza Oct 21, 2012 11:49 PM
Thumbs up for the Fuel pump repair video!
I have recently had to replace my fuel pump switch on my F3 and followed the instruction here to the letter and it worked great. I still had other issues re misfiring that I had to fix like the regulator/rectifier and carbs see bazzasmotoblog.blogspot.com.au but this fix for the pump 10/10 great video. Bazza:icon_worthy:
davidcbrf3 Jun 4, 2013 02:21 PM
thanks so much
thanks so much for this info cause the shops tell you that you cant rebuild them and so does honda , i have replaced mine 3 times at 170 each time i had to order it . but i put 17,000 miles on my bike in the last 15 months i ride every day .. you described how to do this so perfect my kid could replace the contacts for me ...THANKS AGAIN this info helps me :icon_clapclap:
JLAvila Jun 13, 2013 11:03 PM
So I did the switch out and it works fine until i put the black cover back on and then it cuts off. The bike still runs and i can rev it up but when i listen/touch the fuel pump, its only puttering maybe only ever 5 seconds. And like I said, it works fine with the case off and i made sure nothing was touching just dont know why its cutting off
xRoland Jul 12, 2013 11:09 AM
Thanks for the how-to, I just completed it and she is back up and running. Mine was intermittent though, sometimes it would work sometimes not.
Killerdimpler Jul 12, 2013 09:12 PM
Where does The hose on the cap go?
xRoland Jul 14, 2013 05:37 PM
downward, i believe its just a vent/overfill hose
Killerdimpler Jul 16, 2013 01:21 AM
Oh thanks man. I took out my feel pump out and didn't remember undoing that hose
two-stroke-brit Oct 19, 2015 11:44 AM
great "how to".
cheers mark
Cbknapp1 Mar 5, 2017 12:18 PM
Awesome post. Very helpful. One question. After I finished the replacement, I went to start my bike (cbr f4 2000). I could hear the battery working fine, but the bike wont start. Just kinda "chuggs" while Im pushing ignition. At first, I guessed the fuel lines were empty and the pump would just need to pump for a little while before the bike would start. But after a while, it still wouldnt start. Is that normal for this replacement? Do i need to just keep trying to start it and let the pump do its thing to fill the fuel lines?
