Hey guys, I just fixed my fuel pump (thank you for the writeup!) and I wanted to advise you that I found the contacts on Amazon and they were only 35 shipped. I saw 49.99 on Ebay before I got these so figured this was worth posting. Anyway, I ordered them and got them in a week.
Thanks again! |
I changed the contacts to my pump few days ago, but still it stopped working today and I had to pull over and "tap" the pump to get it pump again. Is it possible that the spring inside the pump is so weak that it wont push the piston enough to close the contacts properly? The pump itself seems to be impossible to dismantle.
Have anyone tried to bypass the fuel pump and let the gravity do the job (as in F2 model)? |
Originally Posted by Arsi
(Post 1059242)
Awesome write up and instructions. Now I know why I'm always thinking it's time to switch to reserve only to look down at the odometer and see I've only travelled about a third of a tank. I'd say mine's ready for an inspection at least.
Instead of replacing the contacts I just gave them a file to match them up and give better contact. Glad I did it, a noticeable difference and the surging has completely gone now. It holds rpm perfectly when cruising. No hesitation on acceleration either.
Originally Posted by Chuluun
(Post 1020508)
Thanks so much, I just finished repairing my pump. I knew about the repair kit before but didn't have the confidence to do it until I found your how-to.
A few thoughts about the pump itself: It is just an auxiliary pump that maintains pressure when fuel is low. With a full tank you don't need it; I know this because my bike would still run with a full tank even though the pump contacts were completely burned out (worse than in the how-to photos in fact). Then when fuel got low I'd end up at the side of the road. In that case I suppose deliberately running the tank to reserve -- which many of us do habitually as a way of measuring fuel consumption -- is likely to put more strain on the pump and wear the contacts quicker (because it runs faster the lower the gravitational pressure from the tank). If the O-ring seal on the pump is breached and the contacts get dirty they can stick or seize. Make sure that's not the problem before you buy the repair kit. A good squirt of WD40 around the hinge and spring on the contacts might help. Great write-up, thanks again. |
Well I found ONE of these pumps in stock here in Cincy, went and picked it up saturday. Got home to find the plastic cap over the contacts was cracked already! Needless to say, I took it back, and a new one should be in tomorrow. But I also am having an issue finding a way to step down from 3/8" hose to 5/16" on the pump and back up. Any suggestions?
fuel pump switch 18-4615
1 Attachment(s)
i am in the same boat with my fuel pump. the contacts are bad as seen in Ido Dirt's pics and vid. i cleaned them and got them working but i do not want to ride my bike (2000 honda cbr 600 f4) and get stuck on the side of the road. my ? is will the kit for the f3 work on the f4 as just by pics they look they same but everywhere i look theres no cross reference for use on the f4. i would like to save some money in these hard times if possible so if it will fit the f4 i would love to know. thank you
THANK YOU!! This is one of the best posts I have seen on any forum for any topic so congrats. This pump is used on loads of bikes and I've ordered it from the following website to sort my CBR F3:
Honda CBR 600 FV/FW 97-98 Fuel Pump Repair Kit - Point Switch Parts at Wemoto - The UK's No.1 On-Line Motorcycle Parts Retailer Fits following bikes: Honda: CBR 250, CB-1, NT 400 Bros, CBR 600 F, NTV 600 Revere, VT 600 Shadow, NT 650 Hawk, NT 650 Bros, NT 650 Deauville, NTV 650 Revere, VFR 750, VT 750 Shadow, XRV 750 Africa Twin, CBR 900 RR Fireblade, CBR 1000 F, XL 1000 Varadero, VT 1100 Shadow, VTX 1300. Kawasaki: ZXR 400, ZX-6R (ZX 600/636), ZZR 600 (ZX 600), ZX7R (ZX 750), ZXR 750, ZX9R, ZX 1000, ZZR 1100 (ZX 1100), VN 1500 KTM: 950 Adventure, 950 R Superenduro, SMC 950 Supermoto Suzuki: RF 600, VZ 800, RF 900, VL 1500. Yamaha: XV 535 Virago, FZS 600 Fazer, XJ 600 N/S Diversion, YZF 600 R6, XVS 650 Drag Star, XJ 900 S Diversion, FZR 1000 Exup/Genesis, FZS 1000 Fazer, YZF 1000 R1, XVS 1100 Dragstar/Dragstar Classic, FJ 1200. |
Hi.
Can someone with a working fuel pump measure and tell the value of resistance between + and null when the pump is not powered? My pump is not starting at all and doesn't look like it has bad connectors. Mine shows a resistance of 2.3 Ohms. Thanks, George |
| All times are GMT -5. The time now is 02:38 AM. |
