This is weird
RE: This is weird
when he hit the chain link fence it lifted and he went under it and it fell back into place like a curtian. the bottom of the fence is held on by hog rings every two feet to a tension wire two inches off the ground and there not that strong to hold the pressure like the tie wires on the top rail would. Why would I know this cause im also a licensed fence builder and thats one of the questions on the test.
If a car runs into a chain link fence which is more likely to happen.
A) It will stop the car suddenly in its tracks.
B) the top of the chainlink will come down and amazingly return to it's original position.
C) it will go under and lay back down to its original position using gravity to assist.
D) or are you just being a smart ***.
Santos4288
01-03-2012 11:14 PM
