DAMn!
RE: DAMn!
wow, i saw that video like 2-3 years ago!
not sure, i know they redline at like 18,000 from playing Gran Turismo.
ORIGINAL: TennesseeCBRF2
Wow that's nuts. Pardon my ignorance, but what's the difference between a F1 car and an Indy car? My father in law has been going to the Indy 500 every year for like the past 27 years. I always feel stupid when he talks about the race and the drivers and I don't know anything about the sport! How many gears does a F1 car have??
RE: DAMn!
[quote]Quite possibly THE most frequently asked question and the
subject of much debate in rasf1 which generally, after some
technical discussion, deteriorates into a slanging match between
European F1 fans and American Indy fans. Generally speaking,
Indy cars are bigger, faster and more durable whereas F1 cars
are more agile and accelerate faster. As to which is better and
which would win a head to head race? F1 cars are better under F1
regs at F1 circuits and Indy cars are better under Indy regs at
Indy circuits.
Tracks. Indy uses ovals as well as road and street courses - F1
does not. This, along with the use of the safety car, is the
most significant difference between the two series. Whilst
making for interesting discussion, the technical differences do
not have much of an impact from the spectators point of view.
However, Indy's detractors would say that the uniform ovals with
the resulting left turns only, produce a sterile racing
environment which allows no exciting passing. Furthermore, most
accidents will result in the safety car making an appearance
which will close up the field. Again, Indy's detractors would
argue that this produces an artificial racing environment
reducing the race to a series of short sprints which are merely
used to establish the grid order for the final sprint to the
finish.
On the other hand, F1 detractors would argue that because of the
wide difference in performance levels, and the fact that safety
cars are rarely used, there is very little close racing or
competitive passing in F1 and of course as a spectator you
cannot see the entire circuit at an F1 race.
(I must apologize if my cultural bias has become apparent in
this section but as a Brit living in the U.S., I am living proof
that F1/Indy preference is determined by genes not environment).
Weight. F1 cars minimum weight is 585 kg (1,287 lbs). Indy car
minimum weight is 1,550 lbs (704.5 kg).
Brakes. F1 cars use carbon fibre brakes which are lighter and
more durable than the steel brakes used by Indy cars. (Indy cars
are allowed to use carbon brakes on the 2.5 mile superspeedways
at Indianapolis and Michigan. Steel brakes are mandatory at all
the other races).
Ground effect. [AS] It is generally said that ground effect cars
are no longer allowed in F1 but this is not strictly true. All
cars generate ground effect, you cannot 'ban' it, only try to
design the rules to limit the downforce that can be obtained
from it. In F1 this is done by requiring flat bottoms between
the wheels (now with 50mm step). In Indycar they still allow
shaped ground effect tunnels, but with strictly controlled
dimensions and at a minimum height above the bottom of the
chassis.
Turbo charging. Banned in F1 but still allowed in Indy -
although at a much lower boost pressure than was used by F1 cars
in the 80's.
Semi-automatic gearboxes. Allowed in F1 but not in Indy.
Nationality. Indy is basically a domestic U.S. series as far as
teams, venues and drivers are concerned. However, there are 3
venues outside of the U.S. (Surfer's Paradise, Brazil, Toronto
and Vancouver) and an increasing number of foreign drivers. F1
is truly international in teams, engines, venues and drivers
although there is a strong European influence, particularly
British and Italian.
And according to Jacques Villeneuve (Electronic Telegraph
3/4/96): "In the last few months I've done over 5,000 miles of
testing with Williams and I've learned a lot about the
differences between Formula One and Indycars. An F1 car is
slower on the straights but much quicker in the corners. The
engine has less horsepower but the power comes on quicker and
because a Formula One car is lighter and more responsive it
reacts faster to the driver's input and the braking is much
better. Because of its extra weight an IndyCar is a bit more
physical to drive
Indy circuits.
finish.
the other races).
chassis.
in the 80's.
physical to drive
RE: DAMn!
ORIGINAL: NOchknstrips
Or not. Honda has very few engines in f1 right now. Ferrari and Renault dominate most of the enginesin F1 I believe only two cars run Honda engines and those are the honda factory cars.
ORIGINAL: mikey1297
and most of your engines in f1 cars are honda
