Wrist pain need help
Just upgraded to the cbr600rr from an r3 two months ago. I don't grip the throttle or the clutch side grip hard, but my wrists start to have pain after more than 30 minutes of riding. I also do wear short gloves, should I upgrade to forearm gloves or will I get used to this? Thanks
I have no idea what your riding posture is like but...
When I started out I could barely make it a few blocks before my wrists were almost burning from the pain, or I could barely hold the clutch / front brake at a light because everything from the wrist to the fingers were numb as hell.
I looked for any solution I could , tank grips, better hand grips, heavier bar ends to help with vibration. You name it,
Turns out I just had to hold myself up more using my core. (like 74demon mentioned).
After I paid attention to my posture I quickly realized what the problem was. Now I can do 1000 km a day with no wrist problem. (maybe the odd numbness when I get fatigued)
My old bike was an 1984 yamaha seca lol , so I didn't have to worry about it and was totally unaware of how important posture is on a sport bike.
I know you say you came from another bike and your not new to riding , but I have no clue what the positioning on an R3 is like compared to the 600rr.
Maybe you just need to compensate for the difference.
However, maybe you want a more sport touring style bike? Look at how you really want to ride every day, the next 5 years.
My 06 600RR is the only street bike I've ever owned. The first 2 years I had my 600 I suffered from severe wrist pain and numbness in my hands. I eventually realized that when I was on the freeway doing 75+, the wind resistance was pushing my body back, keeping the weight off my hands, and my pain/numbness would subside. As soon as I hit traffic or slow rural roads it would set back in. I had rode my buddies 01 F4I, which has a much more upright riding position, and had no problems. My solution has been to sit up as much as possible and try to keep weight off my wrists. It has helped, but on long (2+ hour) rides, I still have problems. I've read that the 600RR is kind of low on the list of comfortable sport bikes, at least around my 600s generation. I commute a lot on it, and putt around on local roads in the afternoons, which has begged the question if it's the right bike... BUT, when I take it out to that mountain pass that winds around like an earthworm on acid, all the way to 11,000 feet and back... I can't imagine a better bike to be on.
Have you tried squeezing the tank with your legs and utilizing more lower body to help ease the stress on your wrists? When you ride a more aggressive style Sportbike the tendency is to push down on the bars and grip too tightly as opposed to using your legs to squeeze the tank, bend your arms a bit and push forward on the bars....see if that helps. What else might this kind of body position help with?
Cheers!
Cheers!
