clutch and front brake lever habits?
before i started riding my little dirt bike 2 years ago, i had the same problem. will i be able to switch from the bicycle brake levers. to tell you the truth, once you figure out that the clutch is in the left side and you pull it every time you switch gears, the only other lever left is the brake, and since you also use your foot to rear brake, its easy to synchronize.
you will be just fine. let your brain take over. it will come naturally.
now i can get on the bicycle and have no problem knowing exactly which brake is witch and same on the bike.
