Leather or Textile?
Thought I would post this over here as it seems to come up every now and then.
Did a little poking around and found this: Tear and Abrasion Strength by the numbers Pounds of force until fabric tears Abrasion cycles on pavement until fabric fails CottonJeans 4.5 pounds to tear 50 cycles to failure 70 Denier Standard Nylon 4.5 pounds to tear 165 cycles to failure 500 Denier Polyester 8 pounds to tear 180 cycles to failure 200 Denier Standard Nylon 7.5 pounds to tear 275 cycles to failure 500 Denier Cordura 22 pounds to tear 710 cycles to failure 620 Denier Cordura 35 pounds to tear 1200 cycles to failure NEW Competition Grade Leather 80-110 pounds to tear 1200-1700 cycles to failure 1000 Denier Cordura 110 pounds to tear 1780 cycles to failure Air Mesh Kevlar 1260 pounds to tear 970 cycles to failure Stretch Kevlar Blend 420lbs pounds to tear 1800 cycles to failure This is how quickly some materials take to hole: Material Seconds Denim 0.2 to 0.5 Some race gloves 0.6 Most leather gloves 1.0 to 1.8 Keprotec stretch material 0.9 Poor Kevlar 1.0 Two layers of waxed cotton 1.3 1.3mm thick cow hide 3.8 Two layers of 1.3mm thick cowhide 18 Three layers of 1.3mm thick cowhide 55 Two layers of Kevlar plain weave 5.6 Suede 18 Boot leather (generally 2.2mm thick) 20 Leather stretch panels 20.4 There is also this test from a while back: Drag Test "For the Drag Test, samples were stitched to a bag that held a 75-pound sandbag inside a milk crate, then dragged behind a pickup truck..." New, 100% Cotton Denim Jeans ----------------------- 3' 10" Senior Balistic Nylon ----------------------------------- 3' 10" Leather, Lightweight, Nude Finish, 2.25 oz/sq. ft. --- 4' 3" Leather, Fashion Weight, 1.75 oz/sq ft. ------------- 4' 4" Two-year-old 100% Cotton Denim Jeans ------------ 4' 5" Cordura Nylon Type 440 ----------------------------- 18' 3" Kevlar 29 Aramid Fiber, Style 713 ------------------ 22' 1" Leather, Competition Weight, 3 oz/sq. ft. -------- 86' 0" Taber Test "For the Taber Test, the specimen was mounted on a rotating platform and scuffed by two rubber-emery grinding wheels." The numbers represent the number of revolutions until the fabric totally fails. A vacuum clears debris. Two-year-old 100% Cotton Denim Jeans 168 New 100% Cotton Denim Jeans 225 Kevlar 29 Aramid Fiber, Style 713 506 Cordura Nylon, Type 440 559 Leather, Lightweight, Nude Finish, 2.25 oz./sq. ft. 564 Leather, Fashion Weight, 1.75 oz./sq. ft. 750 Senior Ballistic Nylon 817 Leather, Competition Weight, 3 oz./sq. ft. 2600 More to consider... "Finally, protection from road abrasion cannot be guaranteed by a materials abrasion resistance alone. A jacket may have panels of highly abrasion-resistant materials, yet if low-quality stitching joins those panels and the seams come apart upon impact or during a slide, then the abrasion resistance of the panels could count for nothing. Furthermore, an ill-fitting garment may ride up in a slide, contorting the body and exposing the skin. And the best jacket in the world, left unzipped and/or unsnapped, won't give riders the protection they pay for. When it comes to safety, the issues are more complex than just the abrasion resistance of materials." __________________ From another site: The textiles vs leathers debate is all about tradeoffs. Choosing which material to use to cover your hide with and spend your pennies on depends on how much you value individual tradeoffs and ultimately, your intended use and riding conditions. Sounds easy enough, but deciding between textiles vs leathers has had great rider minds in a muddle and increasingly so over the last couple of years as the quality and versatility of both materials has improved so much! Just type in “textiles vs leathers ” into google and you will find that 90% of the results are from forums with the answer ultimately resulting in the fact that it depends on your personal preferences. The problem is that this does not help those new to the biking world who have not had the time or experience to develop their own, well-guided preferences… and so the argument goes on. But, it’s really quite simple if you use the BMI (Best Motorcycle Information) textiles vs leathers test. This test takes the four most differentiating attributes of the two materials into consideration – price, maintenance, comfort and protection. Each attribute is also assigned to either leathers or textiles, depending on which material has the greater advantage in terms of the attribute. After reading the brief summary on each, assign a score out of a hundred to each attribute, giving those attributes that are most important to you higher scores, so that in the end the total score of your four attributes adds to 100. Then add up the score that you gave to the leather attributes and textile attributes, and the material with the highest score is your answer – and best of all it will be unique to your personal preferences. Price - Textiles Motorcycle textiles are cheaper to buy than leathers. It is also much harder to judge the quality of leathers and so you take the risk of paying a lot of money for a suit that does not have quality stitching and construction. (Just beware however that it is widely accepted that your textile suit will probably only survive one crash before you have to fork out for a new pair.) Maintenance - Textiles This one is simple – motorcycle textiles can be thrown in a commercial washer, while leathers will need to be sent to the cleaners. Comfort - Textiles Motorcycle textiles have an all weather capability: vents for when it is warm, liners for when it is cold and water resistance for rain. It breathes more easily than leather, and water slides off it like a ducks back. Leather is also much heavier than textile. Protection - Leather Tests are conducted all the time to compare the abrasion resistance of motorcycle riding gear materials and leather always comes out on top as the most durable material. Furthermore, leather does not melt from friction, it will cushion your fall more than motorcycle textiles would and it offers the best protection against a road rash. The fact that leather also lasts through multiple crashes whilst textiles will probably only last through one, says a lot about the difference in protection and impact between the two materials. The textiles vs leathers debate basically comes down to protection vs everything else. It must be said however, that even though leathers offer more protection, all motorcycle textiles have to abide by EU standards and so its not like they don’t offer you protection at all. Motorcycle leathers just offers better protection – that’s all. If you are a commuter, then motorcycle textiles are probably the best bet. They are more comfortable and have more pockets for storage. Motorcycle leathers are designed for performance riding so you are not able to wear many layers underneath, and if its hot, you’re going to arrive sweating – not good for your next promotion or that honey that you are trying to impress! If you are into extreme riding, then it is unquestionable that leathers are what you need! My personal opinion when it comes to textiles vs leathers is that skin takes a lot longer to heal than discomfort – but then again I don’t commute to work everyday, I am no longer on a budget and I have seen enough to put my safety first – always! I may still go for textile, but for the most part I'm sticking to leather. And my classified perusing has finally paid off, I scored on some A*s track leather pants, GP plus leather jacket and teknic violator boots all for $250. They are all practically brand new. If you are on a budget, start hitting up classifieds on different forums and craigslist. There is always someone who for whatever reason decided to give up riding and is selling gear for cheap. __________________ |
Besides strength, I prefer leather simply for its CDI factor - Chicks Dig It.
^+1 leather looks way cooler
leather hands down. Solid leather for winter n cooler days. And perforated leather for summer n warmer days!!
I wear textile during earlier cooler months and I wear a mesh for the hotter months. I want to get leathers, but even with my textile I ride for 20 minutes, I'm already soaked with sweat
I wear textile. summer winter just remove or add the liner
Heavy Leather, mesh , textile (water proof).
Leather hands down. Nothing protects you better. Find a nice perf leather jacket and you're good to go.
i always prefer my leather for chilly days, interstate rides in any weather, and if i know i plan banging on the bike i reach for my leather, which is Astars. got it for 250 on close out from cycle gear. for store trips, across town to a friends or family ill reach for my t-stunt airflow, which i have fitted with all the CE pads. even with my textile hooked up with pads i still prefer my leather in most cases even on hot days. guys @ work give me a hardtime about rocking the leather all the time, but i guess if i didnt know any better id ride without gear too LoL :icon_doh:
Leather all the time. It's also a beautiful jacket, so that is probably part of it.
