MSD Ignition Digital Programmable Shift Light 89631
This shift light was used for about 2 months. I am selling it because I added a Dynojet Hub and will be using it to control my current shift light. There is nothing wrong with the shift light. I did shorten the GMR cable by cutting a few feet off of it. The cut off wire is included if needed.
This shift light will work on any car or motorcycle. It comes with the GMR cable to get the tach signal to make the install much easier. You can also check out my install "How to" in the CBR954 section.
Digital Shift Light
Installs with distributors, coil packs or coil-on-plug systems ranging from single to 12-cylinders.
Programmable from 100-15,900 rpm down to 10 rpm incrememts.
Six bright LEDs are easy to view in daylight and can be dimmed at night.
Supplied with an easy to install GMR pickup!
MSD's new compact Digital Shift Light is the most universal, easy to use light available! The tiny digital controller inside the compact housing give you the ability to program the rpm activation point through the easy to view LED panel and two programming buttons. When the engine reaches the activation rpm, the six retina-scorching red LEDs alert you to grab the next gear. The Digital Shift Light works with all stock or high-powered aftermarket ignition systems.
Price: $125 shipped
Digital Shift Light
Price: $125 shipped
