NC29 Project
1 Attachment(s)
It all started the day I came off my NC30........
Eventually I managed to get my paws on this NC29, which apparently was previously looked after...... Attachment 30068 Anyhoo, When I started stripping, the more I stripped, the more I had to fork out..... -Stripped the fairings, the Air ducts were cracked and fibreglassed on the inside...it woulda been somewhat okay if they were done properly... - Front forks were leaking badly - Front brakes werent very effective as the forks were leaking onto the brake pads -The bolt that needs to be removed to get the brake pads out was stripped so I cant get the pads off - Rear Caliper Ceased, so it needed a bit of elbow grease coming off. - Subframe was slightly rusted, I removed that and will be prepped for some paint. - Brake fluid Resevoir leaking - Accelerator cable snapped - Screen Cracked - Kick stand bent - Clutch cable from an NC23, so it's slightly longer. Looks like I have my work cut out for me. |
2 Attachment(s)
I'm a newbie at this so it took me a while to figure a few things out :-P
Once the Fairings were stripped Attachment 30066 Subframe removed and ready for a quick clean Attachment 30067 |
2 Attachment(s)
Scrubbed up the Chain and back sprocked.....filthy!
Attachment 30064 Not as clean as I wanted it, but okay for now until I have more time. Rear axle needs to be changed as the bolt and nut on either side is stripped Attachment 30065 |
3 Attachment(s)
Back wheel and back caliper removed
Attachment 30061 Front wheel & forks removed Attachment 30062 Calipers Removed - As you can see all the oil and the pads still in the one caliper :icon_urinal: Attachment 30063 |
4 Attachment(s)
Wheels still in okay condition
Attachment 30057 Exhaust headers removed Attachment 30058 FUGLY rusted headers Attachment 30059 Attachment 30060 |
6 Attachment(s)
Subframe
Attachment 30051 Attachment 30052 Attachment 30053 Rear end Attachment 30054 Attachment 30055 Attachment 30056 :icon_couchhide: |
Anyone know if I can change the NC29 forks to NC30 forks and sill use all the standard bits like calipers etc?
Just got a call to say that the forks are bent and the previous owner was a Retard as the sliders are more useful ornaments now EPIC FAIL......managed to get my hands on NC23 Hurricane sliders, and they look to be identical......the helpful gentlemen at the local bike shop is busy servicing them, replacing seals, oil etc.......
3 Attachment(s)
Cleaned up the rear end, and tidied up the wiring.....looked like a 2 year old re-wired this lol....
Attachment 30021 Attachment 30022 Attachment 30023 :icon_doh: |
Upon further inspection after cleaning up the frame....I noticed that on the CDI it says Power Sports? Anyone know if this is maybe a after market CDI? Never heard of it, and by the looks of it neither has google
Powersport is an aftermarket unit (Shadow) :) |
