My CBR 250RR is not starting
Dear Friends,
I have a CBR250RR bike and it gives a problem when I'm trying to start. Some times, it is starting at the first time. But if I stop the engine & try to start again, I cannot to start it. The starter motor is trying to start the bike and it cannot do it. Pls help me to solve this problem. Thankx. |
Check your battery
It can be a problem with the Carburetor, go for a carb tuneup. I also had the same problem, it seems rectified after the tuneup. If the petrol to air ratio is not proper, more petrol will try to burn and that will precipitate on the plugs as carbon. When it dries up, again plugs will spark.
Depending on where you are it could be vapor lock ..........
