Cbr125r 2011
Hi all I was riding home this morning the bike was running fine untill I stopped at a mini roundabout when I tried to pull away it was like I was reving and releasing the throttle constantly Evan thou I wasn't
the bike was bouncing along. once the revs got to 6-7k it seemed to be ok then after each gear change it done it again sorry this isn't a clear explaintion I'm new to bikes. also when idle it is now at 1k instead of 2k and cuts out when I try to rev it any help would be greatly appreciated. |
Have a look at your IACV (idle air control valve) , make sure its clean and connections are tight , I'm assuming you have FI and not carb, also have you got any fault codes , (maybe not with this fault)
I messed up big time didn't check the oil and have been told I have most likely ruined my engine going to put it in the garage think this is out of my depth now thanks for the reply
I would still check your oil level just to make sure its what they said
Oil was completely empty glad I learned this lesson on a 125 and not something more expensive
Turns out I messed up....BIG I o my have gone and put desiel in her XD
the oil was a blessing in disguise as I now have topped it up before cause serious damage that is for replying to me hoping to be back on the road later today. |
