CBR125 2007 Fuel Injection - Diganostics
Hi Everyone. I'm looking for some assistance.
I've just bought a CBR125 for very little money and it will need some work doing. When I got the bike, a lot of the electrics have been disconnected, the engine is loose in the frame and air box and throttle body wasn’t on very well, throttle cable was off, just to give you an idea of the condition. For some reason the Fuel Injector cable into the throttle body had been cut, and the fuel pump from the CDI has also been grounded to the frame. When the ignition is switched on, you immediately here the fuel pump prime, and continue to prime. If I disconnect this bypassed earth cable, it does not prime what so ever? I have disconnected from the throttle body and we are getting good amount of fuel out. Since owning the bike I have; Drained the tank completely & filled with 10L of fuel. Gone around and reconnected all plugs Re-soldered Fuel Injector back together Completely removed & stripped the throttle body, refitted snug with no air leaks Tested / cleaned the injector and see it spray fuel for over 10 seconds..... When switching the bike on I am getting 5 Long flashes, and 4 Short flashes, from what I understand this is code 54 - and related to the "Bank Angle Sensor" - Bingo, yes it is disconnected..... What I find very strange is that there IS a spark despite the error, but as soon as I bridge the two outside connectors together I loose my spark (Reading up online and this should bypass it) I loose the spark, however the fault code goes on the dash? I'm also not hearing the fuel injector solenoid kick in (although it is quiet) but when I manually bypass that too, it still does not fire? (Although can't control the flow....) I have had two back fires through the exhaust Why would a previous owner have bypassed the fuel pump? Why would the CDI not switch the fuel pump on? Why am I not hearing the fuel injector solenoid when I try to start it? Why do I loose a spark when I bypass the Bank Angle Sensor? I'm at this stage suspecting the CDI could be faulty but does anyone else have any suggestions first? |
Any luck with this?
Hi matey , that post is a few years old now, have you got a problem with yours?
Originally Posted by CaBaRet
(Post 1310406)
Hi , does the bike not start at all, if it turns over you need to keep it turning over for 10 seconds to produce Diagnostic codes, then check the codes by shorting the DLC to produce them, page 5-12 of your manual
3 Attachment(s)
Hi all,
So compression tested the bike a week or so later after this posted and was only about 110psi, so i put it down to that. The bike is actually now completed, it's intensions were to be a stunt bike, so being fuel injected any way was not ideal. I have dropped a carb'd engine into the frame, so obviously fitted carb, cdi, wiring loom, tank, airbox from carb'd version. All runs spot on now, should have videos soon of the wheelies etc, complete stunt cage from Poland, rear handbrake setup Need to complete the front end (got oem panels to fit) and that's about it now :) Complete Cagiva mito 125 front end as well, brembo front caliper :) Attachment 88466 Attachment 88467 Attachment 88468 |
(Post 1310406)
