View Poll Results: Are you using a repaired tire?
Voters: 73. You may not vote on this poll
Who is running a patched / plugged tire
#21
wheelies?
i've plugged a tire with 3 or 4 on the stuntbike a couple of times and never had a problem. used standard plugs and rubber cement. bore it out good, set the plug, cover it with rubber cement and set it on fire. let it burn for a minute or so, blow it out and then let it cool for a while. bonds the plug and tire that way. they stayed in at 100mph plus wheelies, . thats from back when i used to do that stuff.
#24
Ran a plugged by me tire on the rear for over 8k w/o issue and would do it again.
#25
PG..waz up dog....agree , running a plug in the 190 on my 929 , to much tread to ditch , and dont have the cash to replace for awile, not gonna let the bike sit. its not like the tire is gonna explode, if plug fails , the tire will just loose air the same way it did when puntured. so the why risk it thing wood also apply to riding in general, why risk it , i could get a flat?
#26
So true, so true!!! I never thought about it that way. Plug, here I come. I don't ride that hard, YET, anyway. Thanks.
#27
I replaced the flat front I just got, but I was planning on replacing it sometime soon anyway. It was getting old and it was a bargain basement Shinko. If I get another flat, I'll definitely plug it unless it has already lived out most of its life.
#28
A car tire is maybe $125 for 50-60k miles while a bike tire is $200 for about 7k miles. That's about 11x more expensive for the mileage.
I guess it's all relative... I got my pair of Pilot Powers for $198 shipped to my door. I don't ride that much- they will last me a while.
My mustang tires cost about that per/tire and I go through them alot faster.
If I get a flat on a car, I have 3 other tires to support the vehicle for me to safely pull over. If one tire on the bike starts to go, I don't like only having one other tire. I don't want to find out the rear plug/patch is leaking and the tire is really low on air while I'm dragging my knee in the middle of a tight sweeper.
I mean do what you want and feel comfortable doing. I like to do everything I can to be safe... and tires are a huge saftey thing for me personally. Same reason I don't want flush mounts- I feel they decrease visibilty of the turn signals but thats another story.
#29
#30
on
I got a nail right in the middle of my new tire. I got one of those atv repair kits free from work. When you install the plug it folds in half, so it actually looks like two plugs are in the hole making it two plugs thick. I jammed two plugs in the puncture and so the entire plug I inserted was actually four plugs thick. I made sure to coat them in repair sealer, wich i also got from work, before inserting them. It never looses any air.
