I need a great lasagna recipe.
RE: I need a great lasagna recipe.
Dude, here is a classic lasagna recipe that I use. If I vary anything, it's how detailed I make the meat/tomato sauce. Many times I use fresh herbs....basil, oregano, tyme, a hint of sage and some bay leaves. Alway use fresh parseley in the cheese layer mixture. The sauce makes it, so take your time. Make sure it's failry thick/cooked downwhen youfinish it up. If it's too thin or watery, it makes it hard to get the lasagna to keep it's shapeThe recipe below is a combination of a couple of recipes, but is written to make it the quickest...ie: using a ragu sauce for the base sauce. It's still pretty friggin awesome. Another slight change that I might make is using all ricotta cheese instead of mixing ricotta and cottage cheese. It's personal preference as both are very good. Keep in mind many people ruin lasagna by either not cooking it long enough in the oven, making it soupy and watery or cooking it too long and having it come out dry. It's just something you have to master. Keep an eye out while it's in the final part of the oven. Once you get a good bubbleing around the edges it should be ready. Have fun....hope it helps.
Here it goes...
1 & 1/2 pounds ground round
1 jar, large, spaghetti sauce with mushrooms (Ragu Super Chunky Mushroom is great)
1 small, mild onion
1/2 container, fresh mushrooms, sliced
1 clove garlic or equivalent from jar
1 15-ounce container ricotta cheese
1 16-ounce container cottage cheese
1/2-1 cup mozzarella cheese, shredded or in combination with parmesan cheese
Salt
Pepper
[size=3][font="times new roman"]1-2 tablespoons parsley, chopped&
Here it goes...
1 small, mild onion
Salt
Pepper
