Shifter just broke while I was on a ride!!! :(
Old Aug 4, 2007 | 08:54 PM
A4wheelin's Avatar
Default Shifter just broke while I was on a ride!!! :(
[hr]
I just went up to Larch Mountain to try to find a road that I remembered was up there. Well..... I go to downshift and my shift lever is gone. I'm like WTF!!! So I pull over and the lever is tucked in behind the side stand thankfully. The pivot bolt had come unscrewed. Well I didn't have any tools so I just put it on as tight as I could with my fingers. So I kept going thinking I'll just fix it when I get back home. I get halfway up the mountain and go to downshift into a corner and it's gone again. This time the bolt is gone! I pull over shut if down and try to figure something out. Well I didn't think about having to be in neutral to start the bike. So I find a rock to push against the pivot point so that I can click the shifter down to "N". I finally get it there and then have to swing the stand up to start it. So I'm squatting down next to the bike on a hill in pine needles trying to balance it to get the stand up and then start it up. Lastly I had to select which gear I wanted to be in for the whole ride home!!! 3rd was the magic gear. Not too high for the streets or too low for the highway. I was at 9k rpms on the highway though. Ugh. This sucks. Now I have to hope that Beaverton Motorcycle has this bolt tomorrow so I can keep riding. Wish me luck![/align]
Old Aug 4, 2007 | 08:59 PM
sixhundredrr's Avatar
Default RE: Shifter just broke while I was on a ride!!! :(
I took my tools out of my little storage compartment on my RR and put them in my backpack. WTF is the point of a tool kit that is hidden undersomething you need tools to remove? This way, I am prepared for the un-expected problem. I also have a flash light and first aid kit in that back pack.
Old Aug 4, 2007 | 09:30 PM
voodoochyl's Avatar
Retired Moderator
A4...you sound like McGyver. These are the kind of things you don't plan for...way to make do. By the way, I love third gear!
Old Aug 4, 2007 | 09:56 PM
A4wheelin's Avatar
ORIGINAL: sixhundredrr
Yeah I won't ride anymore without at least a leatherman on me.
Old Aug 4, 2007 | 09:58 PM
A4wheelin's Avatar
ORIGINAL: voodoochyl
lol, I felt like McGyver! I was sitting there for a minute with nothing but forest for about 5 sq. miles, wondering wtf I was going to do. Then survivor mode kicked in!
Old Aug 5, 2007 | 03:40 AM
txsmainevent's Avatar
actually that happened to me on my f2, i was on my way to work and the stop sign before work my bolt fell out. luckly a harley rider pulls up and says i live right around the corner ill go get some washers and a metric bolt for u. within 10-15 minutes i was headed to work, dont have to much bad to say bout harley riders cuz of that. that day i went to the bike dealership and ordered a new pivot bolt, its sucks goin for the downshift and nothings there!
Old Aug 5, 2007 | 10:57 AM
fuze's Avatar
Damn dude.. make's me wanna go around my bike and snug everything down...
u know you can just pull the cluth and start it in gear right ? atleast on mine... long as the kick isn't down.
Old Aug 5, 2007 | 04:37 PM
demonchild's Avatar
why do you have to be in neutral to start a bike?
Old Aug 5, 2007 | 06:40 PM
rrasco's Avatar
i had something similar happen to me about a year ago. i just left the bank and i was i think in 2nd when i went to shift and my clutch went limp, i was like wtf, not thinking about it, i stop to check it out. doh! so i put it in nutral and try to bump start it without a clutch, well that went unsuccessful after pushing it up the hill 3 times. then a guy stopped and asked if i needed a ride which was a good thing because my phone had been disconnected about 30 minutes prior to that. had to go pick the bike up a little later.
just as an fyi, if you guys read your manual, part of periodic maintenance is to tighten down bolts. i have also had one of my kickstand bolts fall out and realize it when the stand kept pivoting when i tried to put the bike on it. had to lean the bike on a fence and run to home depot.
Old Aug 5, 2007 | 07:24 PM
james007torres24's Avatar
Y NOt just stay in first till u get home?? seems simple to me.
f4stolenhelp
Sep 27, 2013 03:45 PM
dangerranger21
Feb 26, 2008 11:19 PM
Foght
May 19, 2007 12:28 AM
01CBR929RR
Oct 31, 2006 11:05 AM
Slow900RR
Sep 12, 2006 01:11 PM
