R6 vs F4i
R6 vs F4i
I have an opportunity to trade my 2000 CBRF4 for a 2003F4i or a 2003 R1. I have a bunch of friends that are constantly trading just for the hell of it. I am a female rider and I have not sat on the R6. I like the F4i because the seat is narrower than the F4.
Performance wise, what is the opinion. I am inclined to stick with the beloved Honda because familiarity breeds comfort. I have not ridden the F4i but I am sure it is probably comprable to my current bike.
Thoughts? Suggestions? Advice?
Thanks guys-
Thanks guys-
RE: R6 vs F4i
Sorry, my stupid typo...meant to say R6. I just love Hondas though. Totally reliable, easy to wrench on and nice lines. Just thought I'd see if you all had another opinion. Being that I am not very big, i find the seat of the F4 almost too wide for me which causes me to lose my confidence a little bit.
I am used to a smaller bike but love the power behind my F4. Like I said originally, I have never sat on the R6 so I am not sure if it is a decent bike for a petite rider. I've seen a few women on the F4i but I've seen many more on the R6.
RE: R6 vs F4i
I've never ridden an r6 but my guess is that this is like asking if you should take an rr or an f4i(except one isn't a honda). Do you want more or less preformance. More or less comfort. Who cares if it isn't a honda? Of all the bikes I have owned my 03 f4i has been the most unreliable. It's up to you really.
RE: R6 vs F4i
03 CBR F4i
Engine Type: 599 cc, 4 Stroke - Liquid Cooled - Inline Four
Engine Bore and Stroke: 67 mm x 42.5 mm
Compression Ratio: 12:1
Valves DOHC, 4 valves/cylinder
Carburetion: Electronic fuel injection
Ignition System: Computer-controlled digital transistorised with electronic advance
Claimed Horsepower: 110 hp (82 kW) @ 12500 rpm
Maximum Torque: 65 Nm (47.9 ft. lbs) @ 10500 rpm
Transmission type: 6 speed
Final Drive: Chain
Suspension - Front: 43mm fully adjustable cartridge-type fork, 120 mm travel
Suspension - Rear: Pro-Link featuring fully adjustable gas-charged remote reservoir damper, 120 mm travel
Tire - Front: 120/70-17
Tire - Rear: 180/55-17
Brakes - Front: dual 296 mm discs with 4-piston calipers
Brakes - Rear: single 220 mm disc with 1-piston calipers
Overall - Length: 2060 mm (81.1 inches)
Overall - Width: 685 mm (27 inches)
Overall - Height: 1130 mm (44.5 inches)
Seat Height: 810 mm (31.9 inches)
Wheelbase 1390 mm (54.7 inches)
Ground clearance 135 mm (5.3 inches)
Fuel Capacity: 18 l (4.8 Gal)
Dry Weight (without fluids): 170 kg (374.8 pounds)
03 YZF R6
Engine Type: 600 cc, 4 Stroke - Liquid Cooled - Inline-4
Engine Bore and Stroke: 65.5 mm x 44.5 mm
Compression Ratio: 12,4:1
Carburetion: Suction-piston fuel injection w/38mm throttle bodies (4), w/throttle position and RPM sensors
Ignition System: DC-CDI
Claimed Horsepower: 123 hp (91.7 kW) @ 13000 rpm
Maximum Torque: 68.5 Nm (50.2 ft. lbs) @ 12000 rpm
Gear Ratios: 1st 37/13 (2.846), 2nd 37/19 (1.947), 3th 28/18 (1.556), 4th 32/24 (1.333), 5th 25/21 (1.190), 6th 26/24 (1.083)
Primary Drive Ratio: 86/44 (1.955)
Final Drive: Chain, 48/16 (3.000)
Starting: Electronic
Suspension - Front: 43mm telescopic fork w/adjustable preload, compression and rebound damping, 235 mm travel
Suspension - Rear: Single shock w/piggyback reservoir and adjustable preload, compression and rebound damping, 119 mm travel
Front Fork - Rake & Trail Angles: 24 / 86 mm (3.4 inches)
Tire - Front: 120/60-17
Brakes - Front: dual 298 mm discs with 4-piston calipers
Overall - Length: 2025 mm (79.7 inches)
Overall - Width: 690 mm (27.2 inches)
Overall - Height: 1090 mm (42.9 inches)
Seat Height: 820 mm (32.3 inches)
Wheelbase 1380 mm (54.3 inches)
Fuel Capacity: 17 l (4.5 Gal)
Dry Weight (without fluids): 162 kg (357.1 pounds)
Final Drive: Chain
03 YZF R6
