Need help!
Old Feb 13, 2011 | 08:57 PM
adrenalnjunky's Avatar
sounds like you might have a fried RR that has caused epic battery failure.
Old Feb 13, 2011 | 09:08 PM
cbrzilla10's Avatar
my brain has been burnt out for today. will the bike run at all with a fried RR?
Old Feb 13, 2011 | 09:15 PM
(951) Baby Shortee's Avatar
It will run until the batteries juice runs out... then die, about 30 minutes or so
Old Feb 13, 2011 | 09:24 PM
NateDieselF4i's Avatar
Originally Posted by CBRfenatic93
Try pop starting it. Find a level(its better if its down hill) street. Put it in first gear and hold the clutch in. Start running as fast as you can and then hop on the bike and let the clutch out fast while giving it some gas. It should start and let you get it home. If this doesnt work i have NO IDEA what the issue is.
I hope this helps.
Yeah try to push start it, but I'd put it in 2nd. Less violent that way.
Old Feb 13, 2011 | 09:27 PM
jp_greenville13's Avatar
What?! Nate knows how to push start a bike?! lol
Old Feb 13, 2011 | 09:30 PM
Old Feb 13, 2011 | 09:31 PM
Old Feb 13, 2011 | 09:33 PM
Yep just like losing the alternator in your car. It'll run until the battery gets too weak to keep the spark going.
Old Feb 13, 2011 | 10:15 PM
cbrzilla10's Avatar
You guys are awesome haha. Well the fuse is good, but nothing will go on, not even the lights EVEN when hooked up to another battery. this problem seems like something got unplugged. My brain is doing this: just trying to think of what it could be.
I have wires that connect to the gauges that I have to install and they're kind of exposed (cut, but not stripped) could water touching those have shorted it all? All fuses are good keep in mind.
poo.
Old Feb 14, 2011 | 04:26 AM
jpanside@gmail.com's Avatar
ah i had to run start my 97 f3 so many times. push it up a hill and then back down when you do. gl
