LED Flash Rate HELPPPP Me Guys
So I am wiring led front and rear signals on my buddies 05 rr...
well needless to say i didnt realize on the rrs when you use all leds there is no flash at all just a pulse so my question is... what resistors do i need to pick up and wire in from radio shack? thx guys Z |
This guy seems to have a good plan and from reading the posts it seems to work. He attacehd a drawing of what he did as well. Hope this helps some.
http://www.600rr.net/vb/showthread.php?t=74359 |
you need a aftermarket relay to slow the flash if im picking up what your putting down
na just need this
If you like the fast rate then a resistor is going to be very,very hot when signaling if you are using it.. 20watt 5-15ohm will return to normal. You can get them at radio shack. |
