Just played MOH Airborne demo!
O its the ****. You move around and everything blurs, you run and it blurs. Italians all over the place shooting at you. ITS AWESOME!!! Its gonna be able to use the PhysX card. Go download it now!!!!
Once you download it you'll probably have trouble installing it. EA used Winrar to compress it and when you unzip it and click "install" your PC will probably reboot. Here's how you get past it.
Once its done unzipping in a temp folder, click "install" and let your PC reboot by itself (that is if it does it). Now you should have noticed the folder it was putting the files in. Here's what it looks like on my PC.
F:\DOCUME~1\RANGER~1\LOCALS~1\TEMP
Which translates into this. You need to type it in to get there.
F:\Documents and Settings\Rangerscott\Local Settings\Temp
then click on the folder RarSFX
F: is the harddrive windows is installed on my pc so yours might be C: or something. Its what ever harddrive windows is installed on.
Once you're in the RarSFX folder then click on "setup" (has a little EA symbol by it) and it'll install correctly.
RE: Just played MOH Airborne demo!
its good. i guess. the guns are not the good tho. but sence its like from back way when if cool. i was getting avg 50fps at maxed out and there was no blurry like u said. maby its your pc getting vary low frams IDK. anyways here are some SS from playing.
edit. i had not one issus with installing. just keept hitting next next next......
ORIGINAL: james007torres24
The blur isnt a glitch. Its part of the game. You know when you move your head real fast. You can make out objects but its like a blur. Hold down shift key and run. You'll see what I mean.
There's already mods out for the demo. LOL
There's one for smarter enemy AI, have all weapons, leathal weapons (can be killed in 1 - 3 shots, so can enemy), etc.
http://planetmedalofhonor.gamespy.com/mohairborne/
hellboytt
10-12-2007 09:43 AM
