Home Theater Subwoofer
Alright here's my situation, I have an extra 200watt and and 10in sub in box laying around. I want to somehow wire it so that i can use it for my home theater system. Anyone know how to wirer something like this up so that i can plug it into the wall for power and work off the reciever?
RE: Home Theater Subwoofer
i am guessing it goins in a car right??? well if u know how to put it in a car u should be able to put it in you home.
easy cheap way: just get a ac adapter(the ) OUTPUT: 12V and as high as amps as u cand find and wire it in to power. make sure u find out the polarity first.
like this.
Bester way is to buy a 12V power supply for it here is one
http://cgi.ebay.com/20-AMP-POWER-SUP...QQcmdZViewItem
look around for one.
like this.
You can use a car sub for your home theater. The speakers are basically the same, except car subs are built to handle WAY more power. The problem with using a car sub in a home theater is getting the power ratings of the amp and sub to match up properly. If they don't, you risk ruining the amp and/or sub. The other problem is that your other speakers are probably going to be comparatively underpowered, which can cause a gross imbalance in sound.
To support what Tennessee just said, I had a set of speakers in my car that sounded great for a few weeks, then they sounded blown out after that. I went to a car stereo place and he said the worst thing you can do to a speaker is under power it. Many people, like me, put in good speakers but run the stock stereo and it blows out the speakers...that is why you need an amp for a good car stereo. I guess the point I am making, is you will need enough power for that sub. It could be tricky. I would just buy a hometheater sub to be certain.
ORIGINAL: bobjoezx
first off all home speakers are 8 ohms and car's are 4 if not 2 or 1.. depending on quality and brand.. just buy a home stereo subwoofer.....
heres something for you guys, did you know that every speaker is a microphone and every microphone is a speaker.....only reversed? if you guys have equipment where you can plug a mic in a headset jack and vice-versa try it, sound will come out of the mic and you can use the speaker as a mic! its not necessarily good for the equipment or will you get the best results, but it will work.
dont waste your money on a home sub..make your own..when i get you that website..you will see its much cheaper and better. my brother just did this setup with a 10" infinity perfect..sounds awesome. and just so you dont think im some hack or something..i have $1600 jbl surround sound setup in my house and a jl13w7 and jl 1000.1 amp in my car...i knew what good quality is.
