funny butt hair story
Copied from another board.
*** HAIR
I have recently made a mistake in my life, and I offer my story to all though tasteless, that you may learn from my error. It all started, as many things do, with me having trouble pooping. No, I was not constipated; this was not a regularity problem but a matter of technique.
It seems my ss-hair had grown to such a length that tiny grogans were constantly getting tied up in the matted jungle between my asscheeks. It led to much frustration, with me KNOWING that I still had something to drop, but unable to shake the tenacious turd ***** from its butthair dwelling.
Eventually I would have to do two things: either reach down with somepaper and try to pinch off the lingering loaf (which required careful precision to avoid smearing the creature all over my rear, especially since I had no way of seeing what I was doing) or just go for broke, start wiping, and hope that I could remove all the leftover fecal matter before the toilet paper reached its Can't-Be-Flushed threshold. I was contemplating this problem, when I had what seemed at the time to be a bright idea. "Hey, this is my butt and my butt-hair, right? So why don't I just eliminate all the hair, and then my grogans will flow out like beer from a keg!" I said to myself. It is a statement that will go down in history with a lot of other regretted statements. "How many Indians could there be?" said by General Custer. "Looks like a good day for a drive!" by JFK. "There! America On-line now has complete Usenet access!" by some idiot system tech. Such was my **** shaving idea.
I performed the operation that night, with a cheap disposable razor and a towel to sit on. Starting from the bottom, and shaving from the crack to the cheeks, I began the arduous process of ridding my *** of hair. Occasionally, I would have to clean the razor of accumulated hair, which I did by wiping it on the towel. Slowly, my twin mounds and the between-ravine began to resemble the hairless cheeks of a newborn babe. Finally, I wiped the razor one last time, and surveyed my work. The towel was covered with a pile of hair. My *** was smooth as ivory. I smiled, satisfied, thinking my troubles were over.
Little did I know. I now have a great respect for ****-hair. Like everything in this world God created, it has its mighty purpose in existence. It was only after I had removed it that I started to learn how much I had been taking it for granted. For one, it provides friction. I learned this the next day, when I walked out into the sun heading for class. After climbing two flights of stairs and starting to sweat, I started to notice something unpleasant. The sweat was accumulating in my crack, and was causing the unpleasant sensation of my two asscheeks sliding past each other with every step. I thought about going to the bathroom and wiping it off, but had to get to class. Eventually, I
thought, it would dry. Unfortunately, it did dry, but only after mingling with the microscopic poop -molecules lingering around my brown starfish. When I stood up after class, my cheeks were stuck together with a slimy sticky poop/sweat combination. As I made my way back to my dorm, it started to itch. God-DAMN, did it itch! Felt like a swarm of ants was making its way up and down my crack. Fighting to keep from jamming my hand down there
and scratching away, I rushed back to the dorm. Unfortunately, this exertion caused me to sweat, and when I finally
reached my room, my cheeks were sliding back and forth against each other like a pair of horny cane-toads. I quickly dropped my pants, and attempted to dry my *** off by sticking it in front of a fan and spreading my cheeks.
As I pulled the two mounds of flesh apart, a horrible stench burst free and filled the room. Every dog within a 4 block radius started to howl. I had it worst of all, as the ripe aroma of festering poop/sweat went into the fan and blew back into my face. I fought to keep fr
*** HAIR
RE: funny butt hair story
I was in the hairy situation you were faced with as well (literally), i too the first time mistakenlyfeshly cleaned off all the hair [sm=badidea.gif] [sm=headbang.gif]and just like you suffered consequences for a few weeks. However you learn from your mistakes[sm=yeahsmile.gif] and what i have learned is that one must not shave it clean rather just trim the hairs with some scissors. When you trim it, the hair is neither long nor too short and problem is solved. [sm=goodidea.gif]I hope my message helps you![sm=signs003.gif]
