COD4 - no fighting in the war room (campaign)
i was looking for strategies, im on this level on hardened and can't get through it, check this youtube video out on vetern level. its amazing.
http://www.youtube.com/watch?v=H3x6vrEa2kk
it took me a few tries to beat it on hardened but the trick is to try and memerize where the enemies are in case you die and have to redo a certain section. you can see from the vid that he knew where guys were gonna be. also it may sound dumb but the faster you go the better. your guys will only go as fast as you so the faster you gun through a section the more help they will be to you when it comes to picking up the slack and capping off extra bad guys.
ORIGINAL: PlayfulGod
I used god mode on it
Anyways, yeah that level sucked. I must've played a thousand times before I fnally got through it. I probably played on normal mode though.
