Car wrenchers ?
What do you mean by "messing up"? If you're talking as to why they're dirtier looking on the part above the threads... that's usually caused by a leaking/seaping valve cover gasket, specificly the o-rings that go around where the spark plug holes are. I wouldn't worry that much about it... if that's what you mean, again, by "messed up".
~ASE certified Mechanic of 6 years.
Yep, the black gunk on the "outside" on the spark plug is burnt oil from a leaking "o" ring on the head... no big deal, but if you ever take the valve cover off it is an easy/cheap fix.
Your plug electrodes look a little too ash grey. They might have just been overdue to be replaced, or you're running a little too hot of a spark.
