Overheat problem
Old 05-29-2017, 01:45 PM
Robinhood's Avatar
Default Overheat problem
Okay so I have a 09 cbr 600rr. The bike has been overheating as far as up to 270, I replaced the thermostat and the housing and the sensor into the houseing and until last night I could not get my fan to turn on, which the fan turned on a 253 which I know is way to high it should be around 220 the temp bounces drastically up and down 10+ degrees once it warms up. I have done a complete flush of the coolant multiple times. I can't figure out why the bike is running "so hot" unless I'm getting a false reading. Any thoughts on this would be greatly appreciated.
Old 05-29-2017, 02:09 PM
CaBaRet's Avatar
Hi welcome to the forum, temperature very much dependant on type of riding you ie traffic or motorway, but before you worry too much about stripping anything down ,have a look at buying one of those laser temperature guns , they are very cheap and could give you a more reasonable ideal of the temp
Old 05-29-2017, 02:17 PM
Robinhood's Avatar
The temp hits the 270 at idle with a rather large fan blowing on it and the oils light will flash then drop suddenly back to 250 then bounces from 230 all the way to 270
Old 05-29-2017, 03:32 PM
wes 17's Avatar
Could be water pump issue. The impeller could be damaged or not functioning correctly. No flow no cooling ?
Keep us posted as you go.
Old 05-29-2017, 04:04 PM
Robinhood's Avatar
I got a temp gun took my bike for a quick ride it's 60F outside today and the gauge was reading 220 when I parked it checked the water temp with the gun and it was reading 135-140. Possible reasons why?
Old 05-29-2017, 05:10 PM
Robinhood's Avatar
Drained the coolant and found some metal shaveingsso decided to pull the water pump and here's what I found, also it did still turn but was harder then exspected. [img]webkit-fake-url://7a8eb912-0a2e-4190-8037-06765faa7199/imagejpeg[/img]
Old 05-30-2017, 12:49 AM
CaBaRet's Avatar
Hi Robinhood, picture didn't come through but I take it your water pump is shot?
solololos
09-19-2013 06:53 PM
02goblin
04-29-2008 11:36 PM
BigNate354
04-21-2008 01:19 PM
1k06rr
02-08-2008 06:43 AM
null84
10-14-2007 07:23 PM
Quick Reply: Overheat problem
