Newbie from Ohio
Old May 29, 2010 | 08:51 AM
brewersprts's Avatar
Default Newbie from Ohio
Hey guys. I'm a longtime rider, but new the cbr's. I'm from Springfield, OH.
I just recently traded a TL1000 that needed some help for a 08 CBR600RR that needs some help too.
Anyways, I can't wait to get it together and get riding.
Old May 29, 2010 | 09:43 AM
Kuroshio's Avatar
You had the "Widowmaker" and came to Honda? Welcome to the Light Side of the Force!
What kinda help does she need? Beside someone to ride?
Old May 29, 2010 | 09:57 AM
regener8ed's Avatar
welcome to the cbrf!
Old May 29, 2010 | 12:46 PM
JHouse's Avatar
Yes. Welcome to the world of reliable handling. I wasn't familiar with the TL1000 so I found this scary info on Wikipedia:
Design Flaws
Suzuki designers needed to find creative solutions to make the TL1000S a viable sportbike. V-twin motors are longer from front to rear than standard inline four cylinder motors used in most sportbikes. In order to keep the wheelbase as short as possible engineers separated the rear shock absorber/damper from the spring. The spring was located on the right side of the bike and Suzuki developed and employed a rotary style rear damper that provided its damping characteristics through rotating arms. A similar version was also used on the Suzuki TL1000R. The rear shock was similar to suspension dampers used on Formula One race cars, but didn't adequately address that motorcycles require longer suspension travel. As a result, the rotary damper did not have enough oil to handle the rigors of motorcycle duty and would quickly overheat. The lack of oil volume would also cause the oil to quickly degrade, losing viscosity which added to the problems of inconsistent suspension properties.[1]
The front forks had 10mm's less suspension travel than traditional motorcycles which made it easy to overwhelm the front suspension as well. Other problems with handling were caused by a swingarm that had too much lateral flex. When the rear axle was tightened, it would flex the swingarm and cause the chain to become too tight. If owners were to adjust the chain according to the owners manual, the chain would be tight enough to limit rear suspension movement and in some extreme cases would cause the rear suspension to lock up when ridden in excessively bumpy conditions, further degrading handling characteristics.
Old May 30, 2010 | 12:18 AM
kilgoretrout's Avatar
Administrator - Retired
Welcome to the forum, brewer! If you have any questions for the 600RR crew, let 'em know!
Old Jun 1, 2010 | 01:19 PM
hondajunkie's Avatar
Official Welcome Crew Junkie
Hi & welcome aboard brewer!
arcotc
Jan 13, 2021 02:45 PM
CapoCam
Nov 3, 2009 06:31 PM
reimbrandt
Mar 2, 2009 04:39 PM
tnbracn2
Aug 30, 2007 06:42 AM
yubraggin
Feb 25, 2007 09:08 AM
