New & need help :(
New & need help :(
hey im melissa and im having an issue with my 06 cbr600rr the other night coming home on freeway i noticed my blinkers werent working so got home changed the fuse and thought that was the end to the problem the next day the fuse blew again so i replaced it again and now the left blinker works but when i switch it to the right all the lights on the bike strobe and i dont know whats causing it to do that if anyones heard of something like this please help
when going through your wires,pay special attention to any wires that you find drilled into the frame.. if the previous owner did a shorty wiring job, he/she may have jumped off of a factory ground " earth wire" and its loose or drilled their own, but if your getting more than one thing effected. i want to say they jumped off of a factory wire.. so i would pay special attention to any wires that are spliced and leading to the frame.. carefully tug on these connections, they should be tight enough to apply a a pound or so of pressure, if someghing pulls right out. you'll know where your problem is and save yourself a trip to the dealership at eighty dollars an hour... keep us posted.. let us know what you come accross and take a picture if need a second opinion..
well we put the wires all together tested it and jiggled all the wires and it was still doing a strobing headlight and no right turn signal and the fuses didnt pop until we turned it off and back on again then we tested continuity in all the wires to the gauge cluster and headlights and everything checked out fine my next test will be to see if its the switch do you have any pointers on testing that?
