new member and need help
hello im new to the forum.
i have a 99 CBR900RR, i just brought my bike out from winter storage and im leaking fuel all over the place. it appears to be comming from a T that is connected to the fuel line it splits the fuel between 2 carbs. it was leaking on both sides at the same place i took the carb pak off and split them and replaced the gaskets on the T one side stopped leaking, but the other is just as bad as before. i was woundering if one of the carbs has a plugged jet or a float is stuck will it cause it to leak? or could it be another issue i am about 95% certain i got the correct size o-wring for the T's seeing as the one side stopped. any help or thoughts would be greatly appreciated Matt |
welcome to CBRF
post this up in the 900rr section, there is a lot of people there that will help you out. |
