just got my hands on a '96 cbr1000f
I just recently obtained a '96 cbr1000f, though she's not pretty she is a beast. I got the bike by trading the guy the '90 ninja 250r straight up (win in my book). I'm looking to turn her into a streetfighter, naked sportsbike, whatever you want to consider it that's what I'm gonna do. The only piece that I'm having a hard time deciding on is what style headlight to use. There are multiple ones that I think would look good on it but if anyone has any suggestions I'm definitely up to hearing what you think. The only thing I have my mind really set on is the color, going with flat black.
I'm new to forums so if the image doesn't want to show, my bad. A little help on the situation would be awesome, and also I'm not allowed to access my photo's and albums. My best guess is it's because I'm a newb
well you definitely found the place for hurricanes! welcome to CBRF!
and thank the lord we have another fighter-er here. as far as headlights, what are your plans for the front end? are you sticking with a bar, or clip on?
buell headlight
v-rod headlight
mt-03 headlight (what i'm using)
standard 7in round headlight
two 4 in headlights
any of the other fighter headlights
projector lights out of a car
the possibilities are endless. throw up a build thread in the fighter section and get to it!
buell headlight
v-rod headlight
two 4 in headlights
I actually found some I'm at least 95% sure I'm gonna go with, they're 2 4" rounds already flat black (so I don't have to paint them). As for mounting I'm just planning on going with fork tube mounts, then I can get rid of the bulky bracket running across the front and fix up a way to mount gauges off the tube mounts above the lights. A little fabricating will have to take place to mount gauges but it ain't nothing I can't handle. As soon as I get clearance to add photos to my albums then I'll post some pics of the process as I get thru it
thanks for the welcome from everyone, I need to pull the carbs and clean them, check the floats and make sure they're set properly and the jets aren't clogged with anything. Then I need to pull the valve cover and adjust the valves cause there's a good chance it's never been done, but all in good time. Thanks to the awesome people here at cbrf I now have a workshop manual, was able to track down a couple wiring issues with the wiring diagram. As I attempt to raise her from the grave I'll add pics of the progress, and thanks in advance to everyone for any advice thrown my way!
