Honda cbr600f4i starter switch problem
So I recently got a 2003 cbr600 and when I go to start it for the first time it's starts right up. I will drive for about 15 min and then turn off the bike and if I try to go start it again, nothing. I don't hear any clicks or even the starter. But if I let the bike sit for 15 min after it cools I'm assuming it will fire up again. Could it be a bad switch or starter. Thanks in advance
Yeah - same thing happened to me - same symptoms - it was the starter button - over time the contacts get dirty or fur up with verdigris which leads to intermittent switch problems and eventually failure if not treated.
Open up the clam assembly housing the starter switch and clean up the contacts with some electric contact cleaner and a cotton bud - after that it should start fine. I got the same issue with the indicator switch not turning on the indicators a few weeks later - again I cleaned the contacts and it was fine (I also covered the contact in some electrical silicone grease to protect it from the damp).
Alright I'll try that. I'll let you know what happens. Thanks so much man. This bike would be so cool if I can go to the gas station and not have to look funny while I run with the bike just to start it
No problem - hopefully it's just a dirty switch and an easy fix - (also check the condition of your battery terminals and cables - make sure that they are not dirty or corroded) - when the bike heats up the electrical system experiences extra resistance which lowers amperage - so an electrical system that will work with dirty/corroded switch contacts when cold will have a harder time working after extra heat is introduced into the system due to the amperage drop.
If this doesn't fix it then we can look further down the chain in the elctrical system.
