Cbr 900rr 1995 suddenly stopped
Old Mar 25, 2024 | 05:18 PM
Petter92's Avatar
Default Cbr 900rr 1995 suddenly stopped
Have a cbr 900rr suddenly stopped at highway.
after i have lights but no starter button working
Just cranks with a screw driver between start rele terminal. No power to the coils. What can it be the rektifier is new tryed 2 pulse generators no volt on the wires to coils. Where to start check ? Maybe broken ecu?
​​​​​​​and thx for tip to where to start checking.
Old Mar 26, 2024 | 11:00 PM
dannoxyz's Avatar
RR and pulse-generators have nothing to do with cranking bike.
Trace electricity flow from battery to starter. Measure following:
1. resistance at starter-solenoid grn/red terminal to chassis-ground, ohms = ???
2. battery power with everything OFF, volts = ???
3. red wire going into ignition-switch, volts = ???
4. key ON, red/blk wire leaving ignition-switch, volts =???
5. blk/red going into start-button, volts =???
6. PRESS start-button, yel/red wire leaving start-button, volts =???
7. yel/red wire at starter-solenoid, volts = ???
You'll have series of measurements:
battery 13v -> 13v -> 13v -> 13v -> 13v -> 13v -> 13v -> 13v -> 13v -> 0v <-- AHAH!!!! -> 0v -> 0v -> 0v starter-solenoid
Problem is between junction where you got 0v and previous point that did have power. Could be corroded or broken connector or wire along way.
Old Apr 11, 2024 | 12:22 PM
VictoriaDi's Avatar
thanks for sharing the update
1970chevelle
Jul 19, 2009 03:40 PM
