929 No spark.
Old Sep 24, 2022 | 03:54 AM
Kelvin9634's Avatar
Default 929 No spark.
Hello troops.
I have a 2001 929.
Went out and done a 100 mile in the summer, absolutely fine. Came the next day and it wouldt start.
On investigation I found the orange connector with earths and lives, under the tank burnt out, and the connector from the regulator to stator (three yellow wires). So replaced both stator and regulator.
New battery fitted. Still no spark at the plugs.
I’ve checked the pink wire and I am getting 0.020v?
Checked continuity on the Cam sensor, and there is no continuity and 17.60ohms?
All the rest of the harness looks ok and connectors. The only thing I see it could be is cam or crank sensor or ECU, however I want to be sure at the ECU is an expensive guess!
Any help would be appreciated. Missing my bike, but the summer is pretty much done in the UK now lol!
Happy to be contacted direct 07907211024
Cheers
Kelvin
Old Sep 24, 2022 | 02:43 PM
dannoxyz's Avatar
Greetings and Welcome!
Might be wiring issue?
Key ON, pink wire should measure around ~9v at ECM connector.
Old Sep 25, 2022 | 11:08 AM
Kelvin9634's Avatar
Key ON, pink wire should measure arouund ~9v at ECM connector.
Yep measured that and I am getting 0.020volts?
Any ideas ??
Old Sep 25, 2022 | 01:55 PM
That's too low of a voltage to actually be a reading. Where are you making that check specifically? At the 4 pin connector of the Ignition Switch, or the 22 pin at the ECU?
Old Sep 27, 2022 | 01:40 AM
Kelvin9634's Avatar
From the 4 pin connector.
Surely it can only be cam or crank sensor at fault or ECU now?
cheers
Old Sep 27, 2022 | 03:22 PM
dannoxyz's Avatar
No, pink-wire is anti-theft circuit and must present 9v at ECU connector to confirm bike hasn't been hot-wired.
Currently ECU is refusing to send spark because it thinks it's been stolen.
Figure out why pink-wire isn't sending 9v to ECU
Old Oct 1, 2022 | 01:01 AM
There's a Zener diode that drops the 12v to 9v. If it's broken, you get nothing. What you're reading is most likely feedback from the ECU.
Old Oct 1, 2022 | 08:17 PM
dannoxyz's Avatar
Flip ignition switch over for view of diode.
When replacing, be extremely careful about orientation.
Black-stripe should face +12v input and unmarked output goes to pink wire.
Old Nov 8, 2022 | 12:41 PM
daryel.corran's Avatar
929streetfighter
Apr 6, 2018 10:19 AM
Conrice
Oct 2, 2014 09:42 AM
javan1
May 10, 2014 12:11 AM
Neil Haywood
Jul 31, 2012 03:00 PM
