2005 cbr600rr
having a issue that haven’t came across before. Little hard to explain but I’ll do my best... when I turn the key and killswitch on nothing happens, gauge doesn’t light up, fuel pump doesn’t come on but they will when I hit the start button but won’t start. I have a video of it if there’s anyone that would be willing to check it out and see what they think |
Videos always help. Throw it up and we'll give it a look. Without seeing it, I'd advise starting with the basics:
Check the battery voltage, then crank it for a bit, and recheck. If either reading is below 10.5V, it's a dead battery. Try it with a booster pack. If the problem goes away, replace the battery (or you can try trickle-charging it, but below 11V, the cells start to get damaged and won't hold a charge very well, so you'll probably end up replacing it anyway) Next up I'd check fuses. Sometimes they don't look burned, so a multimeter is your friend. If this doesn't help, then we can get into detailed troubleshooting Hope that helps |
Thank you
thank you for the reply, it won’t let me load the video up. Says it’s not accepted, but I was messing with it and disconnected the killswitch/start button wire at the wire harness and his gauge lit completely... leading me to believe that the killswitch/start button box on the handle bar is the culprit |
That's a pretty common failure. Probably corrosion around the switch internals, or a broken/pinched wire. Try cleaning up the terminals with sandpaper or scotchbrite
As far as uploading videos, I think most members will host it on youtube and leave a link. I don't know if it's possible to upload directly to the forum |
