Runs on choke only.....
So this 1996 I'm going to work on only runs on the choke. And of course not well when it does run. Is there a "yeh, they all do that" thing these do or is it just the pilot jets being clogged?
Pilot jets clogged with the crappy fuel now a days. Have that happen to me once on my 1988. Cleaned the carbs and problem solved.
Thought so
99 times out of a hundred that's it but thanks for the verification.
Have you checked your boots for cracks and/or improper seating?
Part #6 on this fiche https://www.bikebandit.com/oem-parts...51597#sch20688 |
Yup, have to agree. Worked on many bikes with those symptoms and in most cases, good carb cleaning was the cure, but as Wooferdog suggested, have had boots in one case and in another, missing sync port covers cause vacuum leaks that led to the problem.
Originally Posted by wooferdog
(Post 1324022)
If you have been riding it and all of a sudden it is acting up, it could be you hit a bad pump. The ethanol has separated and you will need to drain the tank and refill with good gas.
Try to find a pump that is non-ethanol. If this is a normal condition, I agree with the above statements that the mains are clogged. |
(Post 1324028)
https://cimg8.ibsrv.net/gimg/cbrforu...62023543e4.png
Is this the right kit for my 96? |
