A question for the intellingenstia
Does my cat absorb more heat by her very stretched out position in front of the fire, rather than assuming the more traditional curled position?
Some days I feel like the little Red Hen.
"Who will help me find and cut the firewood"
"Not I , say the wife, daughter and very useless pair of cats"
"Who will help me stack the firewood, make sure it's dry, then bring it upstairs and actually put it in the woodburner"
"Who will help me enjoy that heat from the logburner?"
" I will , I will"
" I will , I will"
I think you're fishing Teeks,
Cats are the ones to actually radiate the heat. The combustion stove soaks it up and is warmer than physics alone dictates.
The feline adopts a state of catalepsy and begins to transfer its latent heat to the stove, whether combustion, gas or electricity..........
Viz:
A rare shot of an Arctic cat illustrating the radiation FROM the cat - (note the aura around the animal) - to the heater of the latent energy, stored for future use. And.........
The direct transfer method. The animal places its paws on the heating unit for latent heat transfer. Note the absence of aura in this image.
Uncontrolled release of the cat's latent heat can lead to disaster.
This image from where a cat's homeostatic latent heat gland became uncontrolled leading to a cat induced conflagration. This is why this sort of thing is known as a catastrophe..............
Hope that helps.
Cheers, SB
Viz:
Hope that helps.
Cheers, SB
Further research has unearthed the following to support the theory.
″Latent heat″ measures change in internal energy that seems hidden from a thermometer – the temperature reading doesn't change. Heat is energy in the process of transferring between a system and its surroundings, other than as work or by transfer of matter.
Now, The term latent heat was introduced into calorimetry around 1750 when Joseph Black, commissioned by producers of Scotch whisky in search of ideal quantities of fuel and water for their distilling process, made a little known discovery that the latent heat of cats and gin provided his needs - if only he could release it in a controlled way. Ethyl alcohol releases 855 kJ per kg and Teeks cats are big. However, to this day it has proved impossible to harness the released energy in a satisfactory manner for commercial purposes. This is also where the term "as difficult as herding cats" was coined.
But, to assist Teeks in his quest for knowledge, from first hand experience I know his Moggies do like a Gin tipple.............
So with the cat/gin plus woodstove combination on the south Island in NZ, it should prove a warm winter indoors As long as you supply the wood to the wood stove to serve as a catalyst................
Cheers, SB
Cheers, SB
So.
Since it is summer here, my cat who stretches out under under the ceiling fan, is actually using the heat rising from his body to rotate the fan blades thus cooling the room?
I need to find other ways to harness feline latent energy to serve me.
Maybe now the little beastie will earn his keep
That's right Woof,
Cats are actually more useful than most people realise. It's also why there is the saying "Dogs have owners and Cats have staff"
Sebastionbear is only my online persona. Here's a self portrait You'll note the tongue strategically positioned for deep thought.........
Meow......, SB
Meow......, SB
Now, The term latent heat was introduced into calorimetry around 1750 when Joseph Black, commissioned by producers of Scotch whisky in search of ideal quantities of fuel and water for their distilling process, made a little know discovery that the latent heat of cats and gin provided his needs - if only he could release it in a controlled way. Ethyl alcohol releases 855 kJ per kg and Teeks cats are big. However, to this day it has proved impossible to harness the released energy in a satisfactory manner for commercial purposes. This is also where the term "as difficult as herding cats" was coined.
Cheers, SB
Cheers, SB
That is horrible. I love it.
