My babys First Oil Change By Me.
Old 04-27-2012, 04:42 PM
Missynet's Avatar
Default My babys First Oil Change By Me.
Good evening
So I changed oil today and oil filter and placed a bran new battery on my baby.
Now Laugh part is that 2 months ago when I was standing in rep. buying and making a test ride I clearly remember guy telling me that oil is recently changed. And bike is in good riding condition. My guy who came with me to Tell me if I could cope fixing it or not asked him also the second time after he took a test ride.
After that the guy checked the oil again and said yes theres new oil in it.
I know I have sinned cause I should of changed oil few hundred km back.
Strange was that after 600 km in my hand the oil was preTTy blacky.
So I have gathered strenght and time to get my change kit.
Now the Sad part was that the oil filter was attached so tight that by accidently managed to brake it but again laugh point came when I cleaned it and saw that it is actual Honda original. Witch Probably means that the rep. guy had eighter wrong info or he lied cause they have absolutley no warrancy policy.
Heres a pic from the oil filter. Check the attached Thumbnail under the text.
Also one smirking point is when I looked it more closely it ACTUALLY has some Rust on it.
So now I cant wait till I see if the new oil is better for my hungry motor or worst.
A small question... How often do you change your oil?
Someone told me that I need to do that after every 2000 Km with This bike...
My Baybe has New Oil
Old 04-27-2012, 05:09 PM
estate4life's Avatar
February 2012 ROTM
I would say at the least once a year...Twice a year for daily commute.
Every 3K give take....on liter bikes.
Old 04-27-2012, 05:22 PM
74demon's Avatar
the oil color isnt that big of deal. it will get black fairly quickly. the more you change it, the better it will look each time. like estate says, the frequency of changing it depends on how much you ride, but know that oil that sits is not great either.
i ride a lot, 2500 miles or more a month, when the weather is nice. i change it every 2 months/5,000 miles during those times. the months over the winter, i may only put a few thousand miles over those 4-5 months. i'll still change it after then, about the 6 month mark, before i start riding it a lot again. i use synthetic rotella t6.
oil is cheap, motors are expensive and a lot of work....
Old 04-27-2012, 05:33 PM
February 2012 ROTM
Yup...bike will love it at 2500/oil change...2500/mo is super commuter, that's alot of mileage. Vs. Some rider only put 1000/year....doesn't mean they should change oil every 2.5 year...LOL...
How hard you ride also factor.
But don't over kill and change every 1000 miles...new oils must be broken down and their property get thicker.
Old 04-27-2012, 05:36 PM
74demon's Avatar
now we are talking MILES...not KM. you can convert it.
Old 04-27-2012, 06:18 PM
hawkwind's Avatar
I change mine about every 2000 miles (maybe 3000klm) or every 6 months.
This is probably far more frequently than needed, but I ride quite hard and as the other guys have said, it's the best preventative maintenance you can do.
My motor has 50,000 miles on it and when I took the head off recently, the engineer that looked at it was amazed at how good it looked.
It only takes 10 minutes and costs very little, though I think every 2000 klms would be a bit too frequent. There's keen and then there's obsessive
Old 04-27-2012, 07:29 PM
Bugkiller's Avatar
July 2014 ROTM
Thumbs up oil change
I agree with hawkwind. I try to change mine every 2000 - 2500 MILES. I have over 80,000 miles and the engine is sweet.
Bugkiller
Old 04-28-2012, 06:04 AM
ranchome's Avatar
Every 3000 miles, and I also run Rotella T6.
But my cam chain doesn't rattle, so.......
Old 04-28-2012, 09:22 AM
Missynet's Avatar
wow thats good to know.
no worries abou converting miles, Lived in Uk for two years. So I around guess how much it is.
I think I go under obsessive
Will see how baby will act tough coming to work today was really surprise. Cant tell exact change but felt a bit different.
On Monday I have a bit longer run oncoming. That will tell me a fairytale gone bad or better
Old 04-28-2012, 09:41 AM
Sprock's Avatar
Be good to hear your report then.
me I change every 3000 miles - but I do use longer oversized filters with
same pressure and spec's as the oem filter
Quick Reply: My babys First Oil Change By Me.
