Happy Birthday - 27 years old today
You too can have one like this ...... just 1 year of work ... and a nut and bolt restore! They are a highly technical, but beautiful motor....
Attached is "Total cost of ownership" excel record with every maintainance $ spent ( Including registration and insurance ). This equates to $25,572 over 26 year ...... less than $1,000 / year to own one of these machines ( and I still have the original asset which in Aust is now market valued @ $6.5k with this particular bike insured at replacement value of $10,000)
****, I know .... but now a great insight to the exact maintenance of these machines.
I hazard to confess..... - I also have excel spreadsheets for tire wear for every tire, every tank of petrol (fuel consumption), Valve Clearance checks, Carb Sync results, Suspension Geometry......... ect......
Naga.Thai is just an **** spec freak!!!!!
But at least all his bikes are "RIDDEN, NOT HIDDEN".
Make it more visible! I was just roaming around the forums and stumbled on your spreadsheet.
I see you did the valve clearances a lot in the beginning and then there are some great gaps inbewteen. Care to comment on your experience? Valve clearances are one of those things that I judge I won't be able to do myself (atleast not for a forseeable future) and I'm in doubt on when I should haul it to a mechanic to have them checked.
The cost of your valve clearance is also very high, what does this reflect (495 at one point)?
Thanks!
Valve clearances were checked at intervals as per Honda service recommendations. In addition.... - Valve clearances were obviously done when replacing the cam chain & tensioner. This is where you see the cost of $495 you refer to. Closer look to the spreadsheet should show you this.
FYI - as attached are my records of ...
1. CBR1000 Maintenance Record - Valve Clearance.
2. CBR1000 Maintenance Record - HONDA CBR1000F - L 1990 CARB SYNC _ BALANCE. (With comparison of using both gauges & then the Carbtune Pro)
You will also find further info on these where I have posted my "HOW TOs"... in this forum.
